The Storm 223 V1.3 Knex Gun
10,771
32
328
Published
Introduction: The Storm 223 V1.3 Knex Gun
About: Figured it was high time to give this a quick edit. I was an active part of the K'Nex community from about '08, I still occasionally lurk. I did a lot of dumb stuff on here but I'm past it now. I'm currently...
Hi everyone! This is my fourth posted knex gun, the storm 223. This is the penultimate gun in the storm rifle series, but I am releasing a series of other random guns (pistols, shoguns etc.) Anyway, this gun features two never before done trigger mechanisms, and i mean 2, on the same handle, one for the grenade launcher and one for the main gun.
Version history
  • V1.0: This was a gun which looked similar to what it now is, except the sight was longer, it had no mag and it only had one trigger (for the grenade launcher), and the rest of the gun was a block trigger.
  • V1.1: I added a mag and shortened the sight.
  • V1.2 I made a second, external trigger for the main gun.
  • V1.3 I modded the stock's butt to look like the one on the storm 222
Features
  • 2 True triggers
  • Grenade launcher
  • 60 ft range with 3 rubberbands
  • Mag for 20 yellow rods never jams!
  • Mag for grenade launcher
  • Better stock than my previous guns
Cons
  • The grenade luncher will make the grenades explode when firing 1/6 times, and the grenade mag jams a bit
  • Not very accurate
This is my best gun yet, so enjoy!
Step 1: Piece List: Courtesy of Knex_Builder_Freak
connectors:
14 green connectors.
7 light gray connectors
34 blue sphere connectors
23 purple connectors
23 red connectors
45 snow flakes
74 orange connectors
72 yellow connectors
45 gray connectors
Rods
5 red rods + 1 tan
12 yellow rods
56 blue rods
104 white rods
240 green rods
Misc
2 triangle 3 hole panels
26 Y connectors
5 blue clips
22 tan clips
14 blue spacers
Thank you, kbf!
Total = 768
Step 2: Handle and Triggers
This is for the handle and both of the triggers. Just Follow the pictures.
1. Aim
2. Build
3. Add the trigger house side and handle
4. Build the other trigger
5.Add trigger 2
6.Build this
7. Add it and you're done!
Step 3: Stock/butt
Follow the pics
1.Aim
2.Build
3.Add top onto it
4.Build
5.Build
6.Add 5 to 4 (9 lol)
7.Add butt to stock
8.Add other side of frame
9.Connect to what you already have.
Step 4: Main Body + Insides
Just follow the pics
1. aim
2.Build these
3. and these
4-6. and this
7. Add these to the back of the body
8.Add the barrel / mag well
9.Add this to the bottom of the frame
10. Add this to where the sight is
11.Add this to the front
12. Connect the handles trigger mech to the red rod
13. Connect the body to the rest of the gun
Step 5: Main Fake Barrel
This is the barrel of the gun. Follow the pics
1.Make this
2.Different view
3.attach.
You could leave the gun like this if you want to or don't have many pieces left, but then it's just another gun (that shoots 60 ft). skip to the Rubberband stage if you want to.
Step 6: Front Hand Grip
Guess what you have to follow!
1.Build this
2.Different view
3.attach
Step 7: Grenade Launcher
Follow the dog. I mean the pictures
1.Aim
2.Build
3.Different view
4-6. Build
7.Build
8.Connect
9.Add trigger
10.Firing pin
11.Build and add this
12-13.Attach to the rest of the gun
Step 8: Magazine
This is the burrito masters mag again, i just like it. anyway, loosen out the parts slightly on the blue rods to make the ammo fall easier.
Step 9: Adding the Rubberbands
Follow the pictures
Step 10: Loading and Firing
Okay, hopefully you have built the gun. now just to fire it!!!!!
Picture 1 is the ammo
Picture 2 is a close up of the main mag
To load, put 20 yellow rods in the mag of the main gun, and 5 of the grenades in the grenade launcher mag. Pull back the pin in the stock to cock the main gun, pull the external trigger to fire it. Pull back the pin in front of the hand grip to cock the grenade launcher, pull on the small sliding trigger (white rod) to fire it.
Well i hope you like my gun, and i will now start building the storm 224, TJ-SR-V1.3, The Morph gun from the Jak series, The N60 storm from ratchet and clank 3 and anything else that i dream up!
    • Stick It! Contest
      Stick It! Contest
    • Game Life Contest
      Game Life Contest
    • Backpack Challenge
      Backpack Challenge
    328 Discussions
    for some reason my gun sometimes jammes and if it is not jammed it only shoots 1 foot.
    Lol ya. I still think that your AR-4 commando v2 is better than v3. Better for war, anyway. Bolt actions aren't time efficient.
    Why so? My v3 is more powerful and gets better range. It also gets better reload times. I can afford to sacrifice ROF for extra power and better reload, right?
    Hi buttons03, thanks for your advice.  Since reading this comment, I decided to give this girlfriend thing a shot.
    I found out where your girlfriend lives, and I'm secretly dating her behind your back (well, at least until I told you).
    Thanks for the suggestion.
    -DJ
    No.
    You need to get a life instead of insulting everyone over the internet. It almost makes you more of a loser if its over the internet.
    You also need to learn a bit about grammar and spelling.
    "Instead of going around posting "get a life" to everyone else, you could probably get one yourself, going around insulting everyone over the internet doesnt make you tough or anything, it makes you pretty pathetic..."
    do you think you could post how to make one without the grenade launcher? Please and Thank you
    All you need to do is not build it, then replace some of the connectors for a smooth edge. Hope this helps,
    J
