OK Seriously no photos without my hat unless you write for Nip Tuck and this is the firstest ever video I have made so the editing isn't much the shots of the main floor are blurred to Make my wife happy since the Internet is evil and this was filmed with a Hacked DXG-506V meaning I soldered and pigtail with a female minijack so I could use an external microphone.
I'm just Winging it here so if you can think of a way to interest one of those Reality Shows that are so common these day's please let me know.
This Video has been brought to you by the Number Nine and the Letter J.
be well,
mike
http://www.instructables.com/id/How-to-Build-a-Super-Top-Secret-Bunker-under-Your-/
http://tinyurl.com/2b2sx88
Simpson's Joke...
When I lived through the wreck and learned to walk and talk and such things again I told myself I'd have a good book if I could finish the house.
After we moved in I realized I was really really tired and that project got stuck on the back burner LOL.
I just finished up a modification to my sand pumping device and made a video but it takes me forever to edit the things.
It is basically a 13 foot long primable check valve that lets me pull a slurry of sand and water from the bottom of the test shaft and pump it out into the yard and is an incredible time saver considering originally everything went in and out a 3 by 4 foot opening.
http://senseless.livejournal.com/258454.html
Here's a vid of the sand being pumped out during the prototype stage...
I have removed pine tree stumps in a similar manner by digging a deep hole next to the it and washing the sand from the roots then digging and washing until I had plenty exposed stump then I'd saw it off 2 feet below the ground and fill the hole back up.
I could use a simple large drain line I was thinking to make sure the hole didn't over flow. I could jet a pipe horizontally under the house I was thinking so it came out in the back yard and would be a natural drain a couple feet lower thanthe bottom garage floor but I was thinking about your switch idea and I could get a largeelectricvalve and just bypass the flow into the yard when it got high enough then open a valve so it pours into the pit when the level drops.
My only thought on a second gas trash pump is I could get a 2 inch one pretty cheaply compared to an electric one that would pump the same volume of water but I'm big on scrounging up stuff so we'll see.
I made a shorter version of the vid maybe I'll make an instrctable around it...
I'm just wingin it here LOL so any suggestions are much appreciated and I'll message you a different email address for me if you want.
I need to take a break from it so I'm gonna finish up the check valve and get the sand out of the bottom of the thing so I can see if I got the seal back around the pipes and if so pour a smooth floor then just watch it for a long while and mark exactly how high the water comes up the pipes.
I used the last video I made and hopefully gave a summary of what I had done so far in a new
Instructable but the yard is lookin pretty shabby and the wife is giving me some not so subtle hints that I need to get back to the odds and ends the house above still need LOL.
