What is small, cheap, lightweight, easy, economical, efficient, fast & stable?
It's the so called 'SOCK STOVE'!
More words aren't necessary. This is what it is: maybe the best outdoor stove you've ever had!
All you need:
- a flexible aluminium ventilation tube (or flexible alu pipe)
- some metal wire
and, of course
- a fresh wooden stick
- your survival cook pot
Step 1: Preparing the tube
Take a tube with the same diameter as your pot, roll it out and cut two feet of it. Once again folded, this can right away in your survival kit - put it in place of all that useless fishing gear, for example.
Slip one end over your pot and bend the other end in a 'sock' or  'L'-shape.
Solidify the sock with some metal wire - always to have in your kit - and fix it to a fresh wooden stick (I used bamboo in this demo version).
Make a lot of small holes in the sock.
Fix the stove to the ground.
Ready to burn!
weldor says: Jun 25, 2012. 2:58 PM
the tub you are using is NOT aluminum. It is mylar and here in the States it is used as ven hose. While it is reistant to heat, it can burn as is evidenced in your photographs.
But as you stated this is a survival set up.
bricobart (author) in reply to weldorJun 26, 2012. 1:49 AM
I'll complain to those who fabricated it and called it like that!
Don't worry about the stove. It wasn't damaged at all after a few uses, so in a survival situation this would be enough.
You can use a flexible - and a bit heavier - alu pipe also.
weldor in reply to bricobartJun 26, 2012. 9:39 AM
lol. as long as it works- that is what is really important. What part of the UK are you in?
bricobart (author) in reply to weldorJul 2, 2012. 3:00 AM
The Flemish part! ;-)
weldor in reply to bricobartJul 2, 2012. 9:19 AM
waloon?
bricobart (author) in reply to weldorJul 3, 2012. 2:18 AM
You must be kidding, no?
Asking a Fleming if he's maybe Walloon is like asking a Scot if he's English.
Or being a fan of the Red Sox in a crowd of Yankees. ;-)
weldor in reply to bricobartJul 3, 2012. 7:36 AM
Sorry about that one. I figured out my mistake well after I replied to your post. I said to myself, "Self, you really goofed on that one."
bricobart (author) in reply to weldorJul 6, 2012. 8:31 AM
Don't worry mate! I can understand our situation is difficult to understand - even in Belgium a lot of people don't get the picture ;-)
weldor in reply to bricobartJul 6, 2012. 12:52 PM
I really got a kick out of your baseball analogy. It was a good one. Where did you learn English? You sound as if you maybe picked it up here.
bricobart (author) in reply to weldorSep 10, 2012. 5:00 AM
Well, I learned it at school and from Discovery Channel, Mythbusters, Die Hard, Dire Straits and Guns 'N Roses ;-) Never been in the States, but you'll know it when I'll be there!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
