3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The T Leaf : a.k.a. Toilet trowel
For many years I carried the orange plastic trowel when back packing.  Even with the handle drilled out to reduce weight it still weighed 45g.
Needless to say it finally broke at the handle.
Looking at the junk (saved treasures) in the shed for a replacement I noticed I had some Aluminium Capping (approx 0.5mm thick) and an old garden trowel.  These started my thinking and resulted in The T Leaf.
The final weigh in resulted in a larger trowel that was only 39g.
Tools I used :-
A sheet of paper salvaged from the printer.
Scissors.
Black Sharpie
Angle grinder with a metal cut off blade.
Tin-snips.
Flat file.
An electric drill or a hand drill.
A 15mm metal drill bit.
Rat-tail file.
A range of silicon oxide sanding papers.
Practice safe work.
Use ear muffs and safety goggles.  Hold material in a vice or clamps when drilling or grinding.
Step 1The T Leaf : Design and lay out
The gardening trowel that inspired the T Leaf has the approximate measurements.
Length 170 mm.
Widest point 90 mm.
Rounding down to approx 60mm near the point.
The fold in the capping strip was used to add rijidity.
Fold the paper in half-lengthwise.  Using the dimensions above layout your overall shape.  Remember that the final template will be symmetrical along the fold.
Cut along your curve.
5 comments
Jan 28, 2012. 1:32 AMjonnyd55 says:
Why not use your angle grinder to cut a sirated edge for light sawing of roots or grass when digging. You could also get a large rubber grommet to put in the hole. This will make it much more ergonomic :)
Jun 28, 2011. 11:29 AMKaelessin says:
nice! this is awesome.
I've been trying to find a decent backpacking-ready trowel/shovel for years and the old ww2 style ones have seemed to be the only viable option but they're large and heavy for the little use i'd actually be getting from them. This is perfect!
I wonder if a sugru (or oogoo) pad around the thumb hole and along the back ridge would make it more ergonomically ideal too . . .Living in AZ with sometimes rock hard soil would make any digging somewhat painful lol
Jun 28, 2011. 6:22 AMschkip1973 says:
great job! lightweight and simple design..
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Cambronze
If I can make it, repair it, repurpose it, reuse it and recycle it I am happy.
