iImage Information
The Tesla Coil is a Air Core Resonant Transformer consisting of a primary coil and a secondary coil. The primary coil is the part of the device that resonates or vibrates which when vibrating gives of a very strong magnetic field that causes induction in the secondary coil. the magnetic field is caused by first the power from the 120 volt wall outlet is converted into 6500 volts by the transformer then the power flows into the capacitor where it gets amplified then moves along to the spark gap the spark gap acts like a switch without the spark gap the coil will not function it will just burn up your transformer next the power goes to the primary coil and causes induction in the secondary coil thus causes lighting or arcs to be transmitted out of the toroid or topload.
Step 1Parts That You Will Need
iImage Information
The parts you will need to build a tesla coil:
1. 6500 volt 23 milli amp transformer found at amazing1.com
2. 10,000 volt capacitor found at amazing1.com
3. Spark Gap found at amazing1.com
4. PVC Pipe 5-6 inches wide 3 feet long Found At The Home Depot
5. Copper tubing (refrigerator tubing) 1/4th inch diamiter 30 feet found at The Home Depot
6. Toriod Found at Amazing1.com
7. # 24-26 enamaled magnet wire or just magnet wire found at electronixexpress.com
Here's a link.
Now, most of their claims are bogus. They're not antigravity, but, as I was saying, the foil is below the thin wire, and they are positioned so that ions travel uniformly on all sides of the wire to the foil. This is made to happen by a 15-100kV DC current running through the small wire and moving down to the foil. The passing of the electricity causes ions to form from the air, which push downward, propelling the mass of the lifter up.
Anyways, my main comment was that the plan to build a Jacob's Ladder AFTER building a Tesla Coil is ridiculous. Everybody knows that the first thing you build when you get a NST (Neon Sign Transformer) IS a Jacob's Ladder..
This Memorial is designed and ran by me.
