Step By Step Plans To Building A 250,000 Volt Tesla Coil by Tesla Coiler
The Tesla Coil is a Air Core Resonant Transformer consisting of a primary coil and a secondary coil. The primary coil is the part of the device that resonates or vibrates which when vibrating gives of a very strong magnetic field that causes induction in the secondary coil. the magnetic field is caused by first the power from the 120 volt wall outlet is converted into 6500 volts by the transformer then the power flows into the capacitor where it gets amplified then moves along to the spark gap the spark gap acts like a switch without the spark gap the coil will not function it will just burn up your transformer next the power goes to the primary coil and causes induction in the secondary coil thus causes lighting or arcs to be transmitted out of the toroid or topload.
Step 1: Parts That You Will Need
The parts you will need to build a tesla coil:
1. 6500 volt 23 milli amp transformer found at amazing1.com
2. 10,000 volt capacitor found at amazing1.com
3. Spark Gap found at amazing1.com
4. PVC Pipe 5-6 inches wide 3 feet long Found At The Home Depot
5. Copper tubing (refrigerator tubing) 1/4th inch diamiter 30 feet found at The Home Depot
6. Toriod Found at Amazing1.com
7. # 24-26 enamaled magnet wire or just magnet wire found at electronixexpress.com
1-40 of 70Next »
Void Schism says: Sep 21, 2009. 5:24 AM
candidate for a circuit diagram maybe?
Chingasman says: Jun 19, 2011. 11:27 AM
second that.
plasmaniac734 says: Nov 3, 2011. 6:26 AM
third that
xFiction says: Jan 25, 2012. 6:00 PM
fourth that xD
Remington900 says: Feb 1, 2012. 11:42 AM
fifth that xD xD
BrunoG says: Apr 15, 2012. 6:46 PM
sixth that
tesla man says: Aug 7, 2012. 11:59 AM
I guess ill seventh that
Ninjakaib says: Sep 6, 2012. 4:13 PM
This means I have to eighth that.
TheNickmaster21 says: Apr 26, 2013. 11:25 AM
Yeah, he should add one.
Anaweir says: Apr 12, 2013. 8:55 AM
seen these, just make sure that you are not wearing anything metal
highvoltageguy says: Nov 15, 2011. 8:28 PM
are u using a mot?
aweis says: Apr 14, 2011. 4:06 PM
i see from the picture that one of the rings in the primary coil is way to close to the other one, makeing it dangerous, and i do not even see th toroid in this picture, it seems more like an advertisement for that website he claims to get the stuff from.
namethatsnottaken says: Dec 1, 2009. 7:33 PM
does this tesla coil actually work , im doing this for a science project and i dont want it to explode in my face
aweis says: Apr 14, 2011. 4:02 PM
well iven if you had a tesla coil that did work, it would be exeedingly dangerous, you would have to make shure that none of the teachers have pacemakers, since the electricity, that will flow through the air will effect that. as well as giant warning labels that say do not touch!!!!! i would actually not reccomend this as a science project, because of how dangerous it is, but if you do make shure anyone around it or goes near it is well informed of the dangers
Xellers says: Apr 16, 2010. 5:34 PM
I know that it has been a while since this was posted, and quite a while since I last visited this page, however, I feel the need to point out that this Tesla Coil does not work and following these plans is dangerous. The author claims that he has achieved sparks that were a few inches in length. Unfortunately, given his apparent understanding of his device and given how poorly it was constructed, even these mediocre results seem somewhat far-fetched. At the moment, I am trying to communicate with an admin to have this instructable temporarily removed until it is made to be up to par with the community standards of this website. Posting dangerous instructions about topics which one does not completely understand not only does you disservice by slandering your name, but it also puts the entire community at risk. Attaching warnings such as "IT WILL KILL YOU INSTANTLY THERE IS NO SECOND CHANCE!!!" does not help.
knoxarama says: Jul 16, 2010. 4:26 PM
does the secondary coil have multiple layers of wire, or is it just one all the way through?
thatinventor1 says: Jul 17, 2010. 11:17 PM
just one layer itsz hard as heck to do
T0C says: Feb 23, 2011. 10:57 AM
It's not that hard but it takes a LOOOOOOOOOOOOOOONG time to do.
M4industries says: Jul 20, 2010. 3:15 PM
Please elaborate on the type of capacitor. Perhaps SKU of item on Amazing1.
puffyfluff says: Dec 19, 2008. 4:19 PM
(removed by author or community request)
chriskarr says: Dec 19, 2008. 4:22 PM
No fair. I feel sorry for you; nobody deserves to work on something for so long, then get it ripped out of their hands. How much longer until you can get your instructable on the Tesla Coil up? I mean, this guy's isn't up to par.
puffyfluff says: Dec 19, 2008. 4:26 PM
puffyfluff says: Dec 19, 2008. 4:29 PM
puffyfluff says: Dec 19, 2008. 4:30 PM
chriskarr says: Dec 19, 2008. 4:47 PM
I imagine you've heard of lifters - once thought of as antigravity devices, they actually work off of what's known as "Ion winds". The lifters are super-light and consist of some metal foil attached to a wire and a different wire above said foil. The foil goes all the way around the lifter so that efficiency is maximized.
Here's a link.
Now, most of their claims are bogus. They're not antigravity, but, as I was saying, the foil is below the thin wire, and they are positioned so that ions travel uniformly on all sides of the wire to the foil. This is made to happen by a 15-100kV DC current running through the small wire and moving down to the foil. The passing of the electricity causes ions to form from the air, which push downward, propelling the mass of the lifter up.
Anyways, my main comment was that the plan to build a Jacob's Ladder AFTER building a Tesla Coil is ridiculous. Everybody knows that the first thing you build when you get a NST (Neon Sign Transformer) IS a Jacob's Ladder..
Xellers says: Nov 12, 2009. 5:18 PM
In your link it says "provides thrust without expelling mass," I don't think so.
puffyfluff says: Dec 19, 2008. 4:35 PM
Tesla Coiler (author) says: Dec 20, 2008. 1:24 PM
May be be can put our heads together on this problem so that this would be a more efficient plan and Instructable. My Email Address is Jtmotz@hotmail.com
puffyfluff says: Dec 20, 2008. 2:10 PM
I'd be glad to.
ranzau says: Jul 28, 2009. 12:18 PM
Hey just one thing never put the Secondary Coils wire inside the pipe even the ends of it. It can burn out the coil.
Samuel H says: Jul 3, 2009. 3:51 PM
I wasn't planning on that much money, thanks anyway!
Tesla Coiler (author) says: Jul 13, 2009. 1:46 PM
Please join the Nikola Tesla Memorial Society. At http://apps.facebook.com/causes/315646?m=96aaaf39
This Memorial is designed and ran by me.
Samuel H says: Jul 1, 2009. 6:15 PM
how much did all of the supplies cost
Tesla Coiler (author) says: Jul 1, 2009. 7:11 PM
this coil in general cost me 200 dollars USD Do you want a list of the parts with thier prices? if you do email me at teslatech@live.com
aservantofhis says: Apr 3, 2009. 2:44 AM
just a question, what are tesla coils used for and what can they do?
budsiskos says: Apr 12, 2009. 10:00 AM
tesla coils were originally built by nikola tesla as a way to experiment with wireless power transmission (sending electricity without wires) but unfortunately the government went to war before tesla could finish his experiments and his funding ceased. although tesla did successfully transfer electricity wirelessly, today, tesla coils have no true practicality other than electrical companies experimenting with lightning or for an interesting hobby experiment
vince086 says: Jun 9, 2009. 12:54 PM
arent they used in electric toothbrushes to recharge them ?
budsiskos says: Jun 9, 2009. 1:51 PM
no, thats just an air core transformer. they dont work off of resonance but rather induction.
budsiskos says: Mar 26, 2009. 6:31 PM
do you think a capacitor like this one would work?
PowerOnDemand says: Apr 18, 2009. 7:19 PM
Do Not Use These I have just recently purchased 2 of these and the exploded on me.
1-40 of 70Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
