I would suggest putting this project together on a breadboard first and then soldering it up on perfboard if you enjoy it!
Remove these ads by
Signing UpStep 1Do You Have The Parts?
* Small wires for making connections
* Female RCA (TV cable) adapter. I use these for power input on all of my soldered-up projects.
* Female headphone jack (1/8 in. / 3.5mm.)
* Phototransistor. THIS IS NOT AN LED
* 10,000pf ceramic capacitor. #103. This is the same as 0.01uf or 10nf
* 4 different valued resistors. 4.7 Kilohm, 10 Kilohm, 22 Kilohm, and 10 Megohm
* NPN transistor
* 555 timer IC (integrated circuit)
* DIP-8 (dual in-line package - 8) IC socket
****If you don't know where to find these things, head on over to MOUSER.com and search for them! make sure to look at the datasheet of each item before ordering!****
****Note that both the DIP-8 IC socket and the female RCA adapter plug are unnecessary for building this project on a breadboard.
I once found an LED looking thing but instead of clear plastic it was solid back, I don't know what it is...
i have found this is a quick way to check, but it probably not the most reliable.
1. Phototransistor
2. Infrared phototransistor
3. Infrared LED
How to discover which of the three possibilities your LED-looking thing is.
First, shine IR light at it with an IRLED.
Second, shine light from a clear, white LED at it.
You shouldn't get a reading from both.
If it doesn't respond to either, it may be an IRLED itself. in which case you should apply a moderate voltage and current to it and direct it towards an IR-phototransistor. You will now be able to tell what devise you have.
**I have some of those black-lens LED-looking-things. there is a very good chance that they are infrared phototransistors. I believe that the blackness on the lens is to filter out visible light and leave just IR light.
Will I have to alter any of the resistor values?
What's the output quality like? Does it produce recognisable notes?
It would be incredibly hard to play recognizable notes. it's pitch varies directly with light intensity.
Keep up man !
They do seem awfully pricey to me. I just looked and I have 16 in one of my junk drawers. A dozen were salvaged out of an old deli scale. The rest I picked up here and there.
Jameco seems to have them for $1.49
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&pa=202366&productId=202366&keyCode=WSF&CID=GMC
I even have made a similar circuit with just 2 transistors and a cap. it sort of squealed when it was hit by light.
http://i.imgur.com/aMhhJ.jpg
I think the circuit was billed as a fridge alarm or something silly.
