Introduction: The Tornado 480 Command V2
Check my H.A.W.C Version 10.0 too!
This is my first ever: 16-shot, preload-every-shot, moderate range minigun!
It's one of my sweetest looking guns because it really looks like an actual minigun!
The only negative is that the reload system takes a very long time to well.. reload, duh!
The range is about 45 ft with good quality rubberbands that are double-folded.
Weight: 1.02 kg
Length: 71 cm
Pros:
-16 shots
-pretty strong
-two handles
-awesome looks
-16 shots per 5 seconds
Cons:
-the shooting top is a bit flimsy
-long reload time
You likey?
So go build it!
Step 1: Parts List
Rods:
-14 greys
-4 reds
-52 yellows
-35 blues
-116 whites
-158 greens + 16 greens
Connectors:
-65 oranges
-60 yellows
-84 grays
-5 light grays
-17 whites
-13 greens
-28 reds
-22 dark blues
-43 purples
Exotics:
-4 tan clips
-16 ball joint click-ins
-8 small gear wheels (the grey ones)
-16/20 gray spacers
-5 blue spacers
Other things needed:
-16 folded-up rubberbands
Got the pieces?
let's move on then, shall we?
Step 2: The Trigger Pusher Plus the Front Handle
This part is to pull the block trigger small guns, and to have a grip on the front.
Step 3: Bi-pod
This part is to help it stand stable when you put it down.
Step 4: Rear Handle
This part is to have a steady grip on the gun
Step 5: Front
This part is to hold the gatling part in place so it will not demolish itself by spinning without the support.
Step 6: The Engine and the Engine Support
This part is to hold the engine in place which lets the gatling part turn.
The engine comes with the Starburst Spinner set.
Step 7: The Gatling Part
This part is the spinning part which makes the small guns shoot.
pic 6-11: build the part 8 times.
Step 8: Assembly
The pictures speak for themselves...
if you have a problem, contact me on my orangeboard.
Step 9: Loading
pic 1: get the gun
pic 2: pull back the firing pin
pic 3: get a green rod
pic 4: insert at the front
pic 5: click it so it will not come out
pic 6: do this 15 more times
Done.
Step 10: You Are Done!!!
Well Well Well,
you have built yourself the Tornado 480 Command V2
Have fun with my knex gun!!!
