3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Transmuted Victorian Engineer's Journal
Step 4Paint Aluminum
Paint Aluminum
Not much to say here - I put on about 3 coats over a period of 2 days. For the first coat, I used a continual spray, but on the 2nd and 3rd coats I used quick sprays of paint to give some areas a darker finish, some areas a thicker or layered look, and other areas developed unique textures (the smallest piece has a bubbling effect that looks great so I'm hoping I'll be able to make it visible and not covered by the leather binding.
I could have painted only the external sides of the pieces, but because I wasn't sure which side I'd choose as external (and to give myself choices) I painted all sides of the pieces.
The final result looks a little different in photos than when you're holding it, but it turned out great - sort of a metallic copper leather look but with a very interesting surface feel.
6 comments
Oct 2, 2008. 12:51 PMhottie_mchottson says:
I've used the Krylon wrought iron spray paint to make faux iron parts on wooden chests and it works great. One way to cut down on the chipping factor is to spray the painted surface with clear polyurethane varnish either glossy or matte depending on the desired finish. I love this book!
Oct 2, 2008. 10:20 PMFull Frontal Graphic says:
Simple vinegar will etch the aluminum enough to give the paint a good hold, and if left longer, can create some texture. Rinse and dry thoroughly before painting. Nice piece of craft you got there. Looks real steampunky.
Oct 2, 2008. 3:48 PMjennybean42 says:
I love it! What kind of leather is that? I always look at the Tandy catalog and then get overwhelmed by thicknesses, weights, etc. You picked just right.
Sep 28, 2008. 11:04 AMwasabi32746 says:
Very nice, the only thing I would do different would be to use a dry brush painting method, to give it a textured and slightly worn look.
Sep 27, 2008. 5:16 PMWyle_E says:
Cool! I never would have thought of using Krylon Fusion, intended for plastics, on aluminum. Other possibilities are black wrinkle enamel, a finish usually associated with early electronics, and copper-plated steel.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:jktechwriter
