3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Transmuted Victorian Engineer's Journal
Step 8Attach Cover
Attach Cover
The cover consists of two pieces of aluminum that are held together using the small hinges. Each hinge comes with small brass screws (unfortunately they're Phillips head, not slot, so I purchased 16 small brass slot screws and cut off the heads to glue over the holes and to add a few (for looks) along the right edge of the top cover.
I used Gorilla Glue for the hinges... the glue expands (I wish they'd solve that problem) but I used my Dremel again to grind down the glue overflow.
After the hinges were secured, I covered them and repainted the pieces with one last touch up. Then I assembled the journal - weighs about 3-4 pounds... (best guess).
2 comments
Aug 16, 2009. 12:41 AMcryp7ic says:
Why did you decide to use glue instead of drilling and taping a hole?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:jktechwriter
