- Compatible with all operating systems
- Harmless fun: Acts as a second mouse, and goes away when you remove The Trickster from their computer
It's a fun little prank, here's a demo:
Even if you victim is computer literate he will suspect a virus or a remote control software in first place, please observe and stop him before he reformats the entire hard drive!
Another tip - if you really want to conceal the device , best way to do it is to solder a 4-pin header instead of the supplied USB plug, then plug the device directly into the USB socket on the motherboard inside the computer case. However be warned that this last step may result in the entire computer being thrown away out of the window!
Trickster is firmware updatable, so once you had fun with it you can re-purpose it as USB-to-Serial Converter, Propeller Programmer, USB IMU or one of many other application running on the UsbThumb platform.
Remove these ads by
Signing UpStep 1Make It: Tools
Otherwise, to make The Trickster on a breadboard / protoboard, you'll need;
1 - Soldering Iron and solder. Leaded solder is easier to work with, and a 15-40 watt iron is just fine. A conical or chisel tip works well.
2 - Dikes. Diagonal cutters are used to trim the excess leads from components after soldering them down.
3 - A PIC programmer. The PICKIT3 works well, you can pick it up from mouser.
Be careful whom you prank--I wouldn't respond very favorably!
L
You can connect it internally if you do it on a breadboard, too! I think the USB header is standard .1" spacing, too.
