3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Tunecast Auto Universal
I got tired of always having fuzzy reception from my car FM adapter, which is the Belkin Tunecast Auto Universal. There's a few tutorials around, but none for this particular model.
There are a couple of really easy things you can do to boost the transmission power. It seems to make a pretty significant difference to the reception.
The thing is a little tricky to tear down, so I'll post some photos of that process.
Here we go...
*** Disclaimer: Boosting the output power may cause your transmitter to exceed FCC regulations on unlicensed FM transmitters. Neither Instructables nor myself assume any responsibility for your actions; this instructable is provided for learning purposes. You should accurately test the output power of your transmitter to make sure it is within regulation or you may incur a fine or other penalty.
Step 1Remove the buttons
Remove the buttons
The buttons are pretty easy to take off. You can just pry off the "U" shaped preset buttons, which click back into place easily.
The up/down tune buttons are secured to the face with adhesive. You just have to pry up the buttons and deal with the fact that you might have to reapply adhesive. These need to be removed since there's a screw underneath.
4 comments
Apr 21, 2012. 10:31 AMtwocvbloke says:
Looks like it's a more basic version of the Tunecast 3 like what I have (somewhere, I gave up with that thing, kept cutting out during quiet parts of my music!!), as seen in my only Instructable... :)
I wasn't as scientific with my mod though, I just slapped a long dangly wire onto the antenna points and soldered the opposite ends together, works great and has a god range... :)
Jun 17, 2011. 3:04 PMjustlaxn529 says:
hi! does it matter what type of wire I use to bypass the inductor? thanks
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:solis365
