In the following instructable I will show you how to make a slightly more simplified version of a USB Wormlight
But I just want to warn you I will be using mostly images done in MS paint, my camera can't focus on close up objects.
Also, I would like you to know that this instructable was extremely rushed, I had very little time to do it in, and was unable to increase its quality. In my next instructable, I will put much more effort in, and I am sorry if you have trouble understanding it.
Thank you for reading my first instructable..
Remove these ads by
Signing UpStep 1Getting the parts...
First off, you'll need to have a High intensity LED, preferably white. Also you have to know its specifications (like current and voltage draw).
Next you will have to find the correct resistor. Now most of you will already know ohms law, but to simplify it:
Voltage Source - Voltage drop of LED / Current Draw of Led
Example: 5v-3.6v(=1.4v)/ (lets say 75ma which =) 0.075= 18.6 so an 18 ohm resistor.
Another thing you'll need is a USB plug, this is just a USB plug that has nothing connected to it. See picture below.
Finally you will need some sort of epoxy resin. This is just to seal the components and ensure they dont short or get damaged.
You will also need some basic tools like pliers, side cutters a soldering iron etc.
16
comments
Add Comment
Xellers
says:
Tomcat94
says:
Add Comment
