3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The USB Stud Light
Step 3Finishing it off and testing....
Final step:
What you must do is first off make sure that none of the leads are touching. Then mix up some epoxy and slowly apply it over all the contacts and components. After everything is well coated, leave the epoxy to set. This will take about an hour( Well actualy about 7 minutes, but it reaches its hardest point after 60).
Once that's over, all you have to do is plug it into a USB port and watch it light up.
There you go, it's done.
You can connect it to an extension cable and it will work like a worm light
Alternatively, you could plug it into a portable USB charger; of which there are many instructables, and use it like a small torch.
But if it doesn't work, remove it immediately because there might be a short circuit which will damage your USB port, not just the device.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:USB
