3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The USB powered LED CD lamp
The USB powered LED CD lamp is a very useful gadget. It's powered by the USB port, so you don't need any external power supply. The stiff mounting wire, I used acts as a gooseneck and lets you bend the light source in different angles and directions.
Step 1Get the parts
Get the parts
Here is a list of the parts you'll need to make this lamp.
4 CDs or DVDs (and if you're rich, you can even use Blu-ray discs or HD DVDs)
7 5mm White or warmwhite LEDs, I used warmwhite, because that I'm tired of the cold light, you get from the ordinary white LEDs. (I've posted some pictures, so that you can see the difference between the white and the warmwhite LEDs)
7 Resistors for the LEDs. I calculated, that my resistors should be 68 ohms. you can find a very good resistor calculator here.
Some electrical mounting wire. Should be the stiff type (the one with only one thick cupper conductor)
5 AA batteries preferably Duracell, cause they're the heaviest (the batteries are just there to act as a counterweight. Without them, the lamp would just tip over and fall).
A switch (optional)
Some ordinary hookup wire.
A USB male A connector with cord (I got mine from a broken webcam)
Some wire without insulation.
176 comments
1-40 of 176next »
Nov 9, 2011. 4:16 PMcvolckmar says:
I have a challenge here. I have a power source that is 53v DC and I want to use 7 Super bright LEDs. I'm new to electricity and I think that it will blow the LEDs since they run on a few volts each. What size resistors do I need use? And where do I install them? I need to use the 53v source. Please show calculations. THANK YOU in advance =]
May 8, 2012. 2:02 AMno_light says:
add the voltages of the LEDs
subtract from the 53v source
divide with the LED current , most LEDs have 20mA so it is .02 A
so
R=(V1-V2)/.02A
Oct 5, 2011. 7:42 AMnemanja92 says:
hello can someone tel me why i can powered Led lights by USB???
Feb 5, 2010. 11:30 AMtaurusguy88 says:
well i made my usb lamp,
but i connected all the led in series
but the pro is i get a notice on my pc
power serge on usb ...
whts to do with tht ??
Sep 22, 2011. 5:23 AMkresimir says:
you short connected something
Aug 21, 2011. 5:38 PMnodoubtman says:
Hello! : How do you get 68 Ohms resistor ??
So : 7 LEDs 20 mA each, 3.5 V each to run, 5 V usb max.
R = (5 - 3.5) / (0.02 * 7) = 10.71 Ohms near value = 12 Ohms. Which is far away from 68 Ohms resistor.
Can you give me your trick? :)
Have a great day! :)
May 23, 2008. 10:20 AMDrChill says:
Just a suggestion. You may need just one resistor. Just wire it so its between each LED and power. I'm guessing a 1/2 or 1 watt resistor should do the trick... It will save a little solder and 1/2 dozen parts ... Nice job. : )
May 23, 2008. 12:00 PMHandsome-Ryan says:
It is a bad idea to wire LEDs in parallel as you are sugesting.
I'll quote from The Electronics Club:
Connecting several LEDs in parallel with just one resistor shared between them is generally not a good idea.
If the LEDs require slightly different voltages only the lowest voltage LED will light and it may be destroyed by the larger current flowing through it. Although identical LEDs can be successfully connected in parallel with one resistor this rarely offers any useful benefit because resistors are very cheap and the current used is the same as connecting the LEDs individually.
Aug 21, 2011. 8:00 AMnodoubtman says:
Are the led in parallel or series ??
thank you!
CYa!
May 24, 2008. 10:10 PMDrChill says:
"If the LEDs require slightly different voltages -only- the lowest voltage LED will light " No. And how much is 'slightly' anyway ? Is 2v 'slightly' different than 3v ? As long as the resistance is appropriate for each LED and the resistor can handle the load, there's no problem. Since this DIY uses the -same- LEDs, they need the -same- current, so there's no problem. And, as the last line of the quote says,"...and the current used is the same as connecting the LEDs individually." Thats my point. Its the same. It's the same current unless the LEDs -are- different, and if they ARE different then use different resistors, not 7 of the same ... Try it yourself. Its easy to test and see who is right here... I like elegant solutions, not wasting parts, and not scaring people away from simpler solutions without understanding why. If you like wasting parts, I have lots of projects for you to try ... ; )
May 28, 2008. 5:26 AMHandsome-Ryan says:
You should post up some instructables of your own. A.I. and I both have posted instructables where we wired circuits for LEDs. Not that simple LED circuits are that challenging but you might be able to demonstrate what conditions are required to use a single resistor safely.
May 28, 2008. 9:23 AMDrChill says:
Thanks for the suggestion. AI's project is a good candidate for using one resistor for all ( not each ) LED. As long as each LED has the same specs, and the resistor is properly sized, it would work. I started playing around with using the PC power supply as a source of power for projects including an LED Lamp.... I'll keep you posted. Regards.
May 26, 2008. 5:14 AMHandsome-Ryan says:
I'm not scaring people off, I'm stating the generally accepted rule of circuit building.
May 26, 2008. 1:47 PMDrChill says:
Sorry. The Electronics club doesn't have it quite right.
Its NOT a generally accepted rule. Its a waste of parts, and there's no logical justification for it.
I will say that as a design rule, simpler is better.
Here's a link that discusses LED wiring more fully and accurately than the Electronics Club.
From circuitry 101:
http://www.theledlight.com/ledcircuits.html
Mar 3, 2010. 9:06 AMVanix says:
What resistor did you use, not sure if i need any specific type of thing or what... I am making this project for my computers class. Thanks for the help.
Aug 21, 2011. 7:36 AMnodoubtman says:
If you put those on parallel if : voltage = 5v, Current across led = 3.6, 20 mA each led to run, 7 leds total, = 10 Ohms resistor? right?..
why did you put a resistor of 68 Ohms?
Can you explain me please?
Thank You!
Aug 11, 2011. 11:17 PMjbernal1 says:
Thanks for your nice work. Actually your work inspired me to made my own usb lamp, I used your "on-CD circuit" design, but the difference is the base, I did it with Legos!! xDDD Can I share some pictures later?
May 31, 2011. 6:18 AMzsingh says:
Great effort to reduce e-waste. GREAT Keep it up
Mar 5, 2011. 1:39 PMyogesh_nik says:
Amazing use of scrap good to recycle my all scrap CDs.
Feb 3, 2011. 10:04 AMjtc10512 says:
I wonder if you solder a USB port to it, it will act as a USB extender. Since the lamp itself would be taking up a usb port, you could regain the amount of free USB ports on your computer. For that, you would not cut off the data wires.
Aug 9, 2010. 12:05 PMGideon Ackon says:
Why did you add the batteries? Is the batteries going to be charged? Why not the USB connected strait to the switch and the LEDs? Please send me the answer to piechart88@yahoo.com
Feb 3, 2011. 4:39 AMMCzone says:
The Batteries are a counterweight not for power,
just use something more efficient than batteries though.
Sep 8, 2010. 6:58 AMdrf009 says:
what is resistor volt?? 250ohm???
Jun 3, 2010. 2:39 PMnacho.cheese says:
excellent work!!!...
I did one, and it work nice...
May 6, 2010. 8:31 AMgeorgettemarston says:
 Hi my son is doing this for a school project and we cant open the step by step instructions without being a member we have all the parts , could someone paste the instuctions and email to me would be greatly appreciated thanks a bunch,
sweetmaria_33@yahoo.com
Mar 3, 2010. 9:07 AMVanix says:
I am looking at these right now
2.2K ohm, 1/4-watt, 5% tolerance carbon-film resistors sold in packets of 5.
  • 2.2K ohm
  • 1/4-watt
  • 5% tolerance
  • Package of 5
Jan 19, 2010. 5:32 PMmarkymonkeymark says:
@sir Jan 12, 2010. 4:25 AMArtificial Intelligence
- wow nice...its really work... i already made one for my new modding project...soon ^_^ ...
see my worklogs here...
http://s358.photobucket.com/albums/oo30/markymonkeymark/Pc%20Mods/Wirings%20and%20Electronics/?start=20
thanks a lot...
Dec 28, 2009. 7:07 AMpr.sreehari says:
wooow its very nice.
but  5v in usb port is enough to drive those 6 leds??
thnx
Jan 13, 2010. 3:05 AMpr.sreehari says:
 yes u r right
i did it
Jan 12, 2010. 12:45 AMmarkymonkeymark says:
Hi sir Artificial Intelligenc, nice work... im just wondering, what happen to those green and white wires?where did you connect those?white wire connected to red wire(5v+) , and the other one which is the black (grnd), did you connect the green one?
im just a noob and willing to learn...
searching all over the net (Led lights powered by USB)
Sep 21, 2009. 12:47 AMnolimit69nolimit2000 says:
You need to change the a statement in your intro though. "It's powered by the USB port, so you don't need any external power supply." USB is an external power supply. But it looks good.
Aug 28, 2009. 11:39 AMmoribello says:
Hmm...what about lead shot? I went to down to the gun store and bought a 5 lb bag of 00 buck for pretty cheap; I mix it with a little white glue; once the glue is dry it does a pretty good job of holding the shot in place. Lead fishing weights hammered flad and hot-glued on would probably work well, too. Just be careful; that stuff is kinda toxic. The batteries are a cool idea, though - especially if they're dead and are being given a second life as ballast.
Aug 15, 2009. 3:08 PMselectum2 says:
this is totally AWESOME!!!!!
1-40 of 176next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
91
Author:Artificial Intelligence
Hi all, I'm a college student in the copenhagen technical college. I'm currently working with 3D printers and I'm building my own RepRap.
