3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Ultimate ATX Power Supply Mod With USB Charging Ports
I know there is already a bunch of these on here, but I didn't see any quite like this so I thought I would post it, so here it is.
This power supply has 3 12v lines, 3 5v lines, 3 3.3v lines, 1 -12v line, & 2 USB ports.
It uses a 480 Watt ATX power supply and puts out enough power to run most projects.
It cost about $35 for everything including the ATX power supply.
This is also a good way to make those ATX power supplys that most people have sitting around gathering dust useful again.
WARNING
This project involves electricity and sharp tools.
however this power supply only puts out 24v max You should not open the case, when plugged in there is a deadly amount of power inside and the capacitors inside will store a large amount of power for days even when unplugged.
This power supply puts out enough current to start a fire. Make sure to use wire that is heavy enough to handle the current and make sure that there are no shorts.
I AM NOT RESPONSABLE FOR ANYTHING YOU DO WITH THE INFORMATION HERE
I am not responsible if you electrocute yourself or anyone else, if you blow something up, or if you burn your house down so be careful.
Step 1Parts & Tools
Parts & Tools
Parts
  • ATX Power Supply
  • Binding Posts With Banana Jacks
  • Butt Splices
  • Eye Connectors
  • Type A USB Jacks
  • 12 Way Terminal Block
  • Small Piece Of Strip board
  • Miniature SPST Toggle Switch
  • NC Momentary Pushbutton Switch
  • Panel Mount Indicator LED (Mine has a built in resistor for 12v use)
  • High Power Resistors
  • Heat sinks For Resistors
  • Wire For Connecting Everything
  • Super Glue
  • Electrical Tape
  • Zip Ties
  • Craft Plywood Or Other Material To Make Case Out Of
Tools
  • Wire Strippers
  • Wire Cutters
  • Crimpers
  • Utility Knife
  • Pliers
  • Hot Glue Gun
  • Soldering Iron & Solder
  • Drill & Drill Bits
  • Screw Driver
  • Volt Meter
69 comments
1-40 of 69next »
Oct 10, 2011. 8:10 AM1! 5#L says:
24 volt by using +12 v and -12v if want higher current should change diode-12v to a bigger one
Oct 3, 2011. 8:21 AMNightLord says:
Would it be wrong if I connected +5 and +12 outputs in series, to get 17V? That's because I'm trying to charge car battery using ATX, and connecting it to -12V is not the option, due to it's poor current rating.
Oct 3, 2011. 11:27 AMNightLord says:
It seems obvious to me now, what was I thinking :)
Any other suggestions how to get 17V and some decent current?
Aug 1, 2011. 8:30 PMTheinventor94 says:
On the specifications of my computer power supply it says "+5 VDC minimum load is 0.2 A when there is a minimum load of 0.3 A on the +12 VDC and 0.42 A on the +3.3 VDC outputs simultaneously. +5 V minimum load is 1 A for load transient tests." After reading this I still have no clue if I need a Power resistor. How do I know what I need?
Aug 2, 2011. 12:25 PMTheinventor94 says:
Thanks!
Jul 18, 2011. 4:55 AMfgorenc says:
did you wire the atx power on switch like so: http://ubuntuone.com/p/155G/
Jul 19, 2011. 4:35 AMfgorenc says:
i have had it wired like this and had no problems but when i wired another power supply with ps-on wire to the ground it burned the power supply immediately. i read about "ps-on to ground" on wikipedia. i figured out the right way (ps-on to pwr-ok) by my self.
Jul 19, 2011. 7:14 AMfgorenc says:
i just tried ps-on to ground on two power supplies. i gues we now have two ways to turn a power supply on: ps-on to ground or ps-on to pwr-ok. i probably short circuted that other supply that burned. :)
Jul 19, 2011. 10:22 AMfgorenc says:
all i know is i had it wired my way and it's been working for years and it still works.
no additional loads needed. it's not a dell but generic atx.
Sep 1, 2009. 11:57 AMlegoman44 says:
I believe USB ports are limited to 500mA. Are the two USB ports current limited in any way?
Apr 22, 2011. 9:34 PMCyberscann54 says:
my laptop usb allows up to a 1000mA or 1A per port It all realy has to do with the Motherboard and what the psu can handle I have seen some that can supply 2A per port with all the hubs and other stuff out there most computer companies realized the 500mA was not enough and the keep breaking and burning out
Sep 8, 2009. 2:29 PMMaXoR says:
In most cases, it would be wise to use a regulating circuit that will only output 500mA. I believe in this case however, it's VERY useful the way he set it up. I know personally that when I want to charge more then two things off my USB hub.... they both charge slower! I think in this case, it's fine. Cell phones, IPOD's, Blackberries.... all charge at over 500mA current draw. If you want to know why they limit it to 500mA......... there is no reason! There are downsides however: - USB cords stop responding after 16 feet - USB hubs which split one port into 4, only gets 125mA PER PORT!!! USB is nice, wireless is better!
Aug 10, 2010. 8:05 AMVick Jr says:
Very nice job. The only suggestion I have is to make it have molex and motherboard connectors in the back so you can just plug in any power supply withought taking anything apart. You could put the resistors with heat sinks in the wooden case and add a fan and air vent. Then it would be completely modular.
Apr 18, 2011. 6:48 AMiApple guy says:
Me to thats what i`m making
Aug 29, 2009. 4:27 PMdagenius says:
wouldn't the -12 volt line just be the same as the 12 volt line, just with the terminals switched?
Aug 31, 2009. 5:30 AMdagenius says:
oh, so using the -12v as a second groundish thing, but lower? and also, when you say the -12v can be used just like the +12v, do you mean that the -12v can be used with the ground, so that, like before, the -12 acts like a more negative terminal than the ground?
Feb 5, 2011. 2:11 PMwelder guy says:
on the top line it says24 volts. which is positive and negetive? im still learning about dual rail power supplies
Jan 9, 2011. 6:41 PMzack247 says:
well it certainly helps me :D
i have a powerbook 190 that uses 24v and has no 24v adapter.
Jun 12, 2010. 8:51 AMfour_eyes954 says:
What exactly is this for?
Jul 24, 2010. 4:03 AMArchive555 says:
It's a handy power supply that outputs a few different standard voltages so you can bench-test circuits you make, or use it to power devices.
Jul 6, 2010. 11:04 AMcdousley says:
i wouldent want any more than one amp on those is that possible?
Jul 6, 2010. 6:59 PMcdousley says:
how often do you think the fuse would blow? also should i just put the fuse of the value i need or higher or lower? Thanks for you help
Jul 6, 2010. 7:05 PMcdousley says:
hey i got an idea theres like more than one 12v red wire if i used like two instead of all off them would it be less amps?
Jul 7, 2010. 4:45 PMcdousley says:
ok i just heard that about the wires somewhere or maybe i imagined it(Dreaming about power supplies?) ill probably us some fuses. THANKS FOR THE HELP! :D
Mar 23, 2010. 12:46 AMhjartland says:
This is too cool! I hope to build my version and HOPEFULLY improve upon the PSU hacks found here. Nicely done!
Dec 5, 2009. 3:50 PMspeedyspy2 says:
okay so. I just made one of these... here are some pics...
http://i174.photobucket.com/albums/w85/speedyspy2/IMG_6204.jpg
http://i174.photobucket.com/albums/w85/speedyspy2/IMG_6205.jpg
http://i174.photobucket.com/albums/w85/speedyspy2/IMG_6206.jpg
http://i174.photobucket.com/albums/w85/speedyspy2/IMG_6207.jpg
http://i174.photobucket.com/albums/w85/speedyspy2/IMG_6208.jpg
Im gonna add the usb mod soon and make a power switch so i can hide the metal atx behind it.(rite now i need it to turn it on and off)
1-40 of 69next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:rocketman221
I enjoy building electronics & robots. I like building computers as well as writing programs & web sites. I like to build and launch rockets. I especially like to play with high voltage power supplie...
more »
