Step 5Wire Up The Power Supply
ATX power supplys have a minimum load which should be listed on the power supply. Mine requires .3A on the 3.3v line, 1A on the 5v line, and 1A on the 12v line. I used resistors for the 3.3 & 5v lines and a mini fridge for the 12v line.
The formula to calculate the the resistor size is Resistance = Volts / Amps.
I needed 11 Ohms for the 3.3v line and the closest resistor avalable was 10 Ohms which gives .33A and a 5 Ohm resistor was needed for the 5v line.
The formula to calculate the wattage is Watts = Volts * Amps which gives just over 1W for the 3.3v line & 5W for the 5v line.
You should use a resistor that is twice the wattage you need to help keep the temp down. I used 10W resistors for both lines. They are mounted between two large TO-220 heatsinks which was then superglued to the case which keeps the resistors below 110o F.
5V - 5 ohm - 1A - 5W
12V - 20 ohm - .6A - 7.2W
The 12V resistor will get very hot. It should be a 20W resistor or two 10 ohm 10W resistors in series. The 5v resistor should be 10W and the 3.3v should be a 5W.
Using a resistor rated for twice the power dissipated keeps them from getting burning hot.
