Step 6Finish It Up
Check the voltages with a volt meter and if the minimum loads have been met the voltages should be very close to what they are rated at.
If one of the lines is over loaded or shorted the power supply will shut down, pressing the reset button or turning the power off and back on will restart it.
If it overheats it should shut down if that happens turn it off and let it cool down and make sure nothing is overloaded and that the power supply has plenty of ventilation and that its not packed with dust.
Double and triple check the wiring on the USB ports before plugging in an mp3 player or camera and test it with a USB keyboard light if you can.
Make sure that the voltage going to the USB ports is between 4.75 & 5.25v
comment
Add Comment
rocketman221 (author)
says:
says:
Add Comment
