It can convert from 1/8" or 1/4" stereo to either 1/8" or 1/4" mono (with the option to change jack sizes between channels). It can do simple conversion from 1/8" to 1/4" in mono and stereo. It can even split a mono signal into a stereo signal (again, with fully selectable 1/8" and 1/4" conversion options).
It is my hope that I will never need to make another converter again!
Well... until I need two of the same kind.
Remove these ads by
Signing UpStep 1Go get stuff
A 14" x 12" sheet of white acrylic.
An awesome Epilog laser cutter
Red and blue acrylic paint
A paintbrush, water cup and palette
A heat gun
Heat protective work gloves
An 18" metal extrusion
Table clamps
A ruler
A drill with a 1/4" bit
(x2) 3" carriage bolts
(x2) 1/4" nuts
(x2) rubber stoppers
(x6) 1/4" mono jacks
(x3) 1/4" stereo jacks
(x6) 1/8" mono jacks
(x3) 1/8" stereo jacks
(x4) SPDT rocker switches
A DPDT slide switch
Hookup wire
A soldering setup
If you don't have a laser cutter, you can use a service like Ponoko
feed a thin copper wire across the terminal to form a bridge to tie in your resistors assuming you are staying passive
The circuitry need not be complex, an appropriately rated resistor (470-600 R or so works nicely) ) in line with each channel before they're tied together is all you really need (if you want to get fancy, a 10k shunt from the summed point to signal ground is nice, but not strictly necessary).
See this article for a more detailed explanation and example circuits:
http://www.rane.com/note109.html
Or, you could possibly hack this with a power drill, a dremel and some screen printing.
