loading
Step 9: Prep for wall caps
Step 6:
Using 2"x4"s and 2"x6"s to make forms for the wall cap we plan to give it the appearance of thick slate on top of the wall. I looked into buying real slate caps; Pennsylvania Brownstone (I wanted a very traditional look as our house is 150 years old). I knew real slate would be expensive but was shocked at how much it would have cost (basically the cost of our entire project). So we will pour concrete and finish it to look like slate instead.
Start off by connecting the lip of the cap (2"x4"s) with masonry screws to the concrete wall. This will provide a base for you to connect the outside of the form. Screws are placed about every 8 to 10 inches. You can do this by taking the impact drill again with long a masonry bit and predrilling through the wood and concrete. Then screw the wood flush to the wall.
Then we used 2"x6"s to create the outside of the form. These too were connected by screwing through the lip and into the concrete using 6" long masonry screws. Again, this was done with the impact drill and screw gun as above.
You must check that you are staying level with all the forms, as the concrete will be poured to the top of the 2"x6". If they were not level it would be seen in the wall cap itself.
Looks great im jealous but there seems to be too much direct sunlight which might attribute to the algae bloom.&nbsp; How are the koi not eating the plants, will they eat anything they can fit in there mouth so big plants are ok???? Im leaning towards a nice breed of goldfish so i can have plants to help with balancing the pond, Water Hyacinth sounds like money it actually filters the water as well may want to check it out.<br /> <br /> http://en.wikipedia.org/wiki/Water_hyacinth<br />
<p>Water hyacinth is good at absorbing heavy metals and many other toxic things from the water. They'd be okay in a cool climate, but once you reach sub-tropical or tropical temperatures, your pond would be quickly overrun. They can double their mass in 24 hours. Perhaps the koi would eat them? I don't know. I do know that in Australia we have problems with water hyacinth blocking rivers and dams. Just one surviving piece can block a river again in a month or so, and you can never get them all! </p><p>I'd look at azolla and duckweed - both would certainly be welcome koi food. The azolla grows nearly as fast as the water hyacinth, but is much smaller and the koi could definitely swallow them. Duckweed (Lemna spp.) are a bit slower, but even tastier. </p><p>Water hyacinth are definitely beautiful, especially when they bloom.</p>
<p>My koi love to eat water hyacinth. We have a 2-level pond with a waterfall, and no fish in the upper level, so when the plants in the lower pond get their roots munched, we move them to the upper pond to regrow. The koi think duckweed is yummy too, but usually eat it faster than it grows. (I agree with the caution that water hyacinth can be a nasty invasive, but can't survive cold winters - it regularly gets down to -20C here (Ottawa, Canada), and water hyacinths seem to get killed by even a light touch of frost.)</p>
<p>At the risk of sounding hypocritical I've just collected some water hyacinth here in the Philippines. I've retired here, and it's all over the place. I will use it in my aquarium and for my aquaponics, feed young leaves to my rabbits, and mulch the rest for my garden. My aquaponics setup is very small, and it doesn't take much of a change in fish numbers to either starve the plants, or have too many nutrients - I can use the water hyacinth to clean up nutrients, and harvest more plants when nutrients are low.</p><p>I probably won't have more than a square metre of water hyacinths at any one time. I've read that they oxygenate water too - I'm testing that now.</p>
<p>Great pond, those koi will get BIG</p>
Forgot to say what a great instructable this was! Thanks for sharing!
Hi, for filter pump you say you use a 1500 gallon per minute pump, do you actually mean per hour? I am trying to work out the plausibility and numbers for a proposed pond. I would think at 1500 gallons per minute the fish would have to be permanently swimming away from the pump inlet.
1500GPM?! Yowch! That'd be one polished concrete pond!
lol. that is all i have to say <br> <br>
That is awesome! But don't the fish go out the over flow holes?
Impressive! Is the pot empty? You might consider adding some gnarly volcanic rock/other very porous nonreactive stones in it loosely (even just gravel). In addition to algae scrubbers, there's also beneficial bacteria that will aid in eating up excess ammonia. If it works as is then carry on, but might be something to think about :)
Doesn't the cinder blocks you used on the planters messup your ph and leech lime into the pond?
Koi like fairly alkaline water and can tolerate up to 9.0, so it might not be a problem. I used to put little concrete statues in my goldfish tank to keep the pH high.
good sketch
That's an awesome project.&nbsp; I&nbsp;wish I&nbsp;had the time and/or money to build landscaping features like that.<br /> <br /> But I think you meant that you used a 1,500 gallon per HOUR water pump.&nbsp; 1,500 gal/min would typically require a 10&quot; pipe.&nbsp; I&nbsp;think a 1,500 gallon per minute pump would turn that 2,000 gallon pond into a whirlpool!<br />
Very nice instructable!&nbsp; I too dream of building a pond like you when I have a garden one day.&nbsp; I have had numerous aquariums in the past and now have a small 50 gallon pond on my balcony with a few comet goldfish.&nbsp; It's been running super well.<br /> I think your fountian concept is great because it will oxygenate the water and it a very pleasing feature in the pond.&nbsp; I like the high wall around the pond. it gives it character and prevents the fish from jumping out.&nbsp; The overflow is a good idea, but&nbsp;I would&nbsp;put a netting accross it, because the fish do jump out.&nbsp; Better safe than sorry.&nbsp; <br /> Where did you hide your filtration?&nbsp; In my pond design considerations, aesthetically hiding a large filtration unit ranks high on the priority list.&nbsp; The larger the filter, the less maintenace is required.&nbsp; The filter also needs to be located in an easy to access/clean location.&nbsp; The filtering options you select will litteraly determine how much time you will need to spend maintaining, so I'm very curious what you have selected for that.<br /> In terms of water quality, I also monitor nitrates (N03), they are not as toxic as NH3 or NO2, but they do tend to accumulate to stressfull levels for the fish.&nbsp; In addition, NO3 is&nbsp;a fertilizer and that is what leads to algae problems.&nbsp; In the cycle of the fish poop,&nbsp;it satrts as&nbsp;toxic NH3 which gets processed in toxic N02 by one typeof bacteria, then the N02 gets processed to the less toxic N03 by a second&nbsp;type of bacteria. Both these type of bacteria require oxygenated water to operate.&nbsp; The N03 accumulates at the end of the cycle and there are 3 (4) ways to deal with it: <br /> 1- plants use it as fertilizer, so put fast growing plants that have their roots in the water (can be in a pot).&nbsp;&nbsp;when they grow, they absorb/export the N03.<br /> 2 - partial water change&nbsp;10% every week or 2 to slow the accumulation of N03.&nbsp; This would be more effective in&nbsp;maintaining water quality than 2 complete water changes/year.&nbsp; When you do a complete waterchange, &nbsp; you also eliminate all the useful bacteria that keeps you eco-cycle going.&nbsp; It takes weeks/months to re-establish it.&nbsp; This would be when the toxic NH3 and NO2 will spike until the tank is cycled and the bacteria equilibrium is re-established.<br /> 3- there is a 3rd type of bacteria that absobs the N03 and that just releases harmless N2 (nitrogen = 79% of what's in the air).&nbsp; But the challenge is that this type of bacteria needs a low oxygen environment.&nbsp; So a traditional filter with high oxygenated water flow does not work well.&nbsp; In nature, this type of bacteria lives deeper in the substrate at the bottom of the pond where there is little oxygen.&nbsp; You can recreate this in a pond or an aquarium by having a deep sand bed.<br /> (4)- If all of the above is not done and there is a bit of sun, this is where the ugly algae bloom comes in to consume the N03.&nbsp; It's nature's way of dealing with it to re-establish a healthy balance.<br /> <br /> So in all my experience, I learned that there is no need to fight mother nature with chemicals.&nbsp; Once I understood the eco-cycle that I&nbsp;was trying to replicate at home, I could make sure that all the parts of the cycle where fulfilled and then enjoyed very healthy, low maintenance aquariums/pond.<br /> <br /> It would be great if after a year or two, you updated your instructables with what you would have done differently (if anything) with the hindsight of experience.<br /> <br /> Again, great job, I am really impressed with the concrete work!!<br />
That is a serious project! i like the pot-waterfall thing, how come in some pictures it is green (which i like) and in other pictures it is plain terracotta? just a different pot?<br />
Same pot. The older pictures show the new terracotta pot while it still has the clay color, the green is actually algae growing on the pot over time as explained in step 14: Build and install the fountain, second paragraph last couple of sentences...<span style="text-decoration: underline;"><span style="font-weight: bold;"><br /> </span></span>
Looks great. The only question I have is how secure is&nbsp; it from being a drowning hazard to small children? I understand that first they would have to be able to crawl over the pond wall, but kids can be pretty resourceful when the sound of moving water attracts them, and they learn that there are fish to watch, they'll be back for sure.<br />
&nbsp;How do you keep both the raccoons and the great blue herons from turning your lovely fish into a buffet table? &nbsp;Everyone I know in our central Ohio area has stories about how their numbers of expensive fish &quot;disappeared&quot;....some without a trace.....(heron) or with minced koi at the edge.(raccoon). &nbsp;Just wondering. &nbsp;Sounds like a beautiful project, but in our area....a futile effort. &nbsp;&nbsp;
Looks great but how do you stop algae from growing in the Summer. I built a koi pond also but had to abandon it because it got bunged up with algae in the summer depite circulating water
as with any real estate location location location!&nbsp; I find placing my ponds -I&nbsp;have 3 and a fountain; bird bathes galore throughout my garden where its mainly shaded and cool with just the morning sun helps a lot!&nbsp; Full sun grows algae at warp speed and so does a pond stocked with too many fish, thus producing an abundance of poop to fertilize the algae.&nbsp; The rule of thumb is 1 inch of goldfish per 5 - 10 gallons of water.&nbsp; An adult or large koi require a minimum of 25 gallons to live in.&nbsp; Goldies can grow quite large!<br /> <br /> You can also use barley straw to lower or is it raise? can't recall off hand the water pH which provides a less attractive environment for the algae to grow in.<br /> <br /> Snails and plants can help too.&nbsp; <br /> The main goal with any ecosystem is BALANCE - too much of anything creates imbalance and lots of extra work!<br /> <br /> BTW the fish also consume the algae and it is the green feed that gives them their brilliant colour!&nbsp; Fish enthusiasts often pay $100's more for fish grown in algae ponds so green its hard to see the fish!<br /> <br /> Please plan ahead how the fish will be kept over the winter if you are in a northern climate.&nbsp; Fish are just as intelligent as cats or dogs and some become quite attached to their people!&nbsp; All that is required is to keep them from freezing - I use a 90 gallon tank out in the unheated garage with a styrofoam top, sides and an air filter or bubbler.&nbsp; The fishes metabolism slows right down to semi hibernation states&nbsp; so they only need be fed about every 10 days, water plants and lily bulbs will keep nicely in the tank too.<br />
My ponds are 100, 80 and 50 gallons... made with the drop in pond liners.&nbsp; Only a couple of koi in the big one then fancy Shebunkins and fantails in the smaller ponds.&nbsp; I made a filter/fountain with a huge terracotta flower pot filled with layers of gravel of various sizes. which runs all summer.<br /> <br /> I even have lovely ceramic pots the big ones that I sealed the hole in the bottom with silicone and grow a water lily in and stock with a couple of little gold fish!<br /> My fountain has a couple of little guys too because I don't leave it running 24/7 and those darned mosquito's are real opportunists!<br /> <br /> So you don't have to go Big to have a nice water feature in your garden - even a betta is happy in gallon of water or the white clouds and tetra's do fine over a summer too outside.<br />
Hey, a lot of algae problems are exacerbated by exposure to sunlight. Try shading portions with plants, etc. depriving it of excessive light can prevetn algae blooms. There's also "natural" products available online and at pond stores called "pond zyme" or "algae zyme" or somehting of the like, essentially they are algae eating enzymes, but I have no personal experience with those. But many fish keepers will say a green pond is a healthy (yet unsightly) pond.
wow, I didnt know that I already have a pound in my house but, due to mosquitos I had to retire the water, hope that works
&nbsp;Actually, fish will eliminate mosquitoes in a pond.
Or just toss in a couple of those 30 cent common/comet gold fish from local pet stores. Comets especially are popularly known as "poor mans koi" (30 cents, can see why) but will easily get as big and beautiful if not more so than koi. They are often in the feeder fish tanks at the pet store.
Yeah, just put in a small pump and get the water moving. Good luck!
nice formal pond!
this is real construction, clean, solid, perfect in everyway.
Great job! And as you requested... ...a question: Exactly what did you use as a concrete sealer that will not harm the fish? I have a similar concrete pond in my front yard and need to seal it. Thansk for the motivation! Mikey
hey today or maybe tomorrow i will get pics of my koi pond that ive been having for around 10 years everything was hand built too even the waterfall
Where do you get the "gasket" material to waterproof the seam between the footer/pond bottom and the side walls?
Something else that might be worth a look is pumping the water through a hydroponic garden. That is the ultimate bio filter, and will probably make for even less maintenance. Once you have a pond, adding a hydroponic garden to it is surprisingly simple and cheap. This site has a lot of info (Australian site, but the main problem with that is just the choice of fish, which you've got covered):<br/><a rel="nofollow" href="http://www.backyardaquaponics.com/">http://www.backyardaquaponics.com/</a><br/>
Hey hey, great work! wanna come to my house and do the same? Just kidding! No I'm not<sub>,</sub><br/>Anyhow, about the Koi. You said they will breed like crazy, and yes, they will but they will also spend a lot of time eating the eggs and (ew) their own young, so if you want to keep them babies you can pull plants after spawn with all the sticky eggs on em and put them in a large tank and let them grow from there. There's plenty of info on teh interwebz about goldfish breeding.<br/>Also, those 30 cent comets that they sell int he feeder fish department at gold fish stores will get as big and as beautiful as koi, only for a LOT cheaper and will also cross breed with the Koi (all types of gold fish are generally the same species) giving you fun different varieties!<br/>Have fun! I know this started as a hardscape project but you may soon find yourself more the fish hobbyist (it's happened to soo many, myself included!)<br/>
Wow, this is beautiful. Clearly you have just a tad of experience... For beginning pond hobbyist, I would like to remind them of goldfish. They are very durable fish, and need less care than koi. Goldfish can often do without the expensive water treatments. And goldfish are really beautiful when viewed from above. That is the way both goldfish and koi were designed to be viewed. Neither looks great when you see them from eye level. Great job. Keep up the nice work.
Huh, I'd never thought about that (regarding the viewing from above). Are there certain types of aquariums that are good for this if you have goldfish?
You know, that's a good question. I'd always thought goldfish to be boring until I saw them in a pond. They were beautiful and very peaceful fish to watch. I never understood why they were bred in their forms until I saw them hovering in the water. As far as aquariums goe, I really don't know. There are some exotic ones with big bubbles under their eyes, and others with growths on their foreheads. There are tons of sites on the web. Read around and see what you find.
Cool, thanks, I'll have to look into it. =)<br/>
how do you get the mosquitos to not reproduce in your pound?
The fish aLSO EAT ANY LARVAE OR MOSQUITO EGGS FOUND! YUM YUM! BIGGER FISH!
There are types of native US fish that eat mosquitoes. They are called mosquito fish. I do believe that goldfish do the same thing.
Mosquitoes need still/stagnate water to reproduce in. The fountain creates ripples in the water so mosquitoes would not lay their eggs/larva here. The water pump also is cycling the water which is not conducive to mosquitoes.
OK First off Kudos!! The pond is awesome!!!.. Now what about teh overall view? Have you finished teh rest of your landscaping project? Also what would you do different if you could do it all over?
Thanks! We did finish the landscaping and it has made the distance from the house to the road seem so much bigger, even with the wall. I added some overall view pictures so it would be easier to visualize the finished project. They are under Step 15. We still plan to add a small fence on top with gates at the wall openings for a little more privacy and give it a "cottage feel". As far as what I would do differently; nothing with the design. But I would probably move the hole for the electrical wires lower and closer to the wall. You can see it in some of the steps. We generally hide it with plants. My original idea was to have a water fall built up in the back corner. We may do that one day, but I am no positive it would fit with the front yard. We love the pond though. My fiance even made seat cushions for the smaller curved wall (idea for another instructable ha!) The only other problem area so far is getting the pot out for winter. The filter tube is in there really tight so it makes it sort of difficult to remove and reinsert. If you use something that can withstand winter it wouldn't be a problem (for example, rocks instead of a ceramic pot).
Idea might be to use those quick disconnects for hoses. Like th eones that they have on the portable pressure washers... Just a thought.. Thank you for the reply and updates...
Beautiful work and an outstanding instructable. Congrats on being named a finalist!
Wow, this is a really nice instructable! Great job!
I honestly was skeptical when I read the title with the word ultimate in it. but this is far beyond anything that I would have thought it was. Great Job, Good Idea and Good structible.
About This Instructable
238,793views
542favorites
License:
More by koncept:The ultimate coffee table The Ultimate Koi Pond
Add instructable to:
