3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Ultimate Nerf Vulcan Mod
We made a NERF chaingun fire about as fast as a 7.62mm M60 Machine gun. That's around 500 rounds per minute (RPM). We did two major modifications, increasing the voltage to the firing motor, and adding a round counter and a paint job.
The total cost on this hack was about $79
Step 1What You Need
What You Need
For this modification, you need the following:
Upping Voltage:
  • 1 x Nerf Vulcan EBF-25 ($50)
  • 2 x 9.6v battery packs
  • 2 x 9.6v battery pack connectors (RadioShack)
  • 2 x Alligator clips
  • 3 x Wire nuts
  • 1 x Ballpoint pen
  • 1 x Chopstick
  • 1 x Mana Energy Potion
  • 1 x A hint of stupidity
Painting/LED Mod:
  • 1 x LED counter from QKit ($18)
  • 1 x Lever/Roller microswitch
  • 1 x LED
  • 3 x Momentary pushbutton switches
  • 1 x 12v miniature battery
  • 1 x Coil of wire
  • 1 x Various paints
257 comments
1-40 of 257next »
May 23, 2012. 7:48 AMalbertkelley25 says:
very cool dude is there any way for it to hold more bullets
May 3, 2012. 8:02 PMRebreg says:
You should modifying the dart holder to hold more darts
Aug 30, 2011. 12:39 AMralchin says:
I cant find battery pack connectors ANYWHERE on the internet. Could someone pls give me a link? Btw i live in australia so i need it to have shipping available here.
Apr 17, 2012. 9:23 AMMSgt_JGC says:
woops! sorry I read your comment half way dude sorry! :(
dude go to radio shack, or go to the shack they have everything!
Apr 14, 2012. 6:23 AMdiskincluded says:
Try Jaycar, if there are any shops near you.
Mar 8, 2012. 1:45 AM~Meme~ says:
I live Australia too, so check hobby stores.
Apr 17, 2012. 9:22 AMMSgt_JGC says:
WOW! I am only 13 and this guy is like 30+ and I solder like a pro.
Apr 3, 2012. 10:55 AMGo_Vikings says:
Thats AWESOME!
Nov 4, 2011. 3:15 PMnof-z says:
at our band camp, we have a nerf war, an now i know how to survive!!!
Oct 28, 2011. 11:16 AMwill7917hero says:
That is beast.
Mar 14, 2009. 11:50 PMzeke34 says:
Ever thought of hooking it up to a power outlet? It'd only last for a few seconds but I'm sure you could get more that 500RPM out of it.
Aug 26, 2011. 9:04 PMfacilitator476 says:
If you wired a rectifier (or is it inverter) before the gun it would convert the A/C current into D/C. Though the 120V might be just a little too much for the gun to handle.
Jun 4, 2011. 11:10 AMtaowyman says:
you rock!
May 10, 2011. 6:52 PMtaowyman says:
how do you mod the newer vulcan?
Apr 30, 2011. 10:16 PMprodo123 says:
Why don't you rip a motor from a vacuum and stick it on the gun?
Mar 29, 2009. 8:42 PMBrown89 says:
nah it would only spark once maybe twice thats about it but from what I learned once you let the smoke out it stops working I hate it when that happens there is a way if you would really want to take the time to convert ac to dc but that requires a bunch more circuit crap and I dunno where to find the diagrams for that but if someone does do it definitely tell me about it I gotta see that
Apr 8, 2009. 5:30 PMCShaffer212 says:
Use one of those brick-transformer-adapters to convert from AC to DC, and put a space around the motor to hold some dry ice, or at least a fan and a heat sink!
Jul 28, 2011. 1:32 AMConrad717 says:
i know this post is old but could you modify a step counter to do this?
Jul 26, 2011. 2:30 PMawesomevampire says:
hey,manaenergypotion
plz make a instrustable for a motion sensor vulcan
thnks
Jul 18, 2011. 8:32 PMGr3at_Whit3_North_Guy says:
In step two which sides are oosirive and which sides are negative?
Apr 2, 2009. 8:29 AMeichermacher says:
What part started melting? Was it the motor or the batteries?
Apr 2, 2009. 2:31 PMSpeedmite says:
the motor. If you put too much energy though a motor the bushings will burn and it will stop working. The batteries might burn in a short circut.
Jul 20, 2009. 8:20 AMeichermacher says:
Could you solve that by replacing the motor with a faster one?
Aug 12, 2009. 6:15 PMSpeedmite says:
Yea, but its more fun working around that. Like adding a super gearing system. But I could make this be such a beast if I used that 4 cycle multi weed wacker/edger/blower/tiller/ect with the air compessor..........
Jul 10, 2011. 9:34 AMSilence says:
Hows about a cheap battery dremmel motor ? Those things and their gear boxes spin at upwards of 3000rpm and sounds like a dentist drill....
Sep 29, 2009. 6:12 PMagent harmsy says:
What about an electric drill motor? :D
Oct 2, 2009. 6:09 PMcodongolev says:
I think that the darts would melt on the way out of the barrel....O_o
Oct 4, 2009. 3:18 PMSpeedmite says:
Drills dont get that hot. And I doubt the air resistance would melt the darts. But would the gears take it?
Jun 9, 2011. 7:05 AMcyberviper42 says:
If you think that then you need more time on a drill. I've had drills heat up to the point of burning me. The fact that i was drilling a 2" hole in 1/2" aluminum might have had something to do with that.
Oct 5, 2009. 5:43 PMcodongolev says:
that's what I was talking about. the gears would probably heat up a ton.
Oct 6, 2009. 8:37 AMSpeedmite says:
But I dont think the darts would melt.
Jan 23, 2010. 10:11 AMeichermacher says:
 That depends on how close the darts move to the gears, and how long they are there.
I don't think they'd be there for long enough to melt, seeing as they are being shot.
Jan 24, 2010. 4:40 PMSpeedmite says:
Exactly. Unless of course, the gears are extremely close to the darts, and are on fire, and somehow are still working and not burning you. That would do it, and it would be epic, but it soooo wouldnt happen
Jul 2, 2011. 9:24 AMjkabiling says:
also unless the gear is made of plastic. if the gear heats up alot, theres a pretty good chance that itll melt and break. idk about the darts tho. they might melt too depending on how close they are to the gear
Jan 24, 2010. 4:42 PMSpeedmite says:
Hehe..... Automatic flaming nerf dart gun.... Hehehehehe......
Jul 17, 2010. 10:30 AMeichermacher says:
That gives me a great idea
Dec 6, 2010. 10:37 AMErezYehuda says:
Why do you guys even bother modding a Nerf gun? It almost seems like you could just build something from scratch.
Dec 14, 2010. 6:22 PMhellonfire30 says:
because its funner to work around it, and then belike YOU JUST GOT PWNED... BY A NERF GUN
1-40 of 257next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
60
Author:ManaEnergyPotion
