The Ultimate Prop Weapon
Introduction: The Ultimate Prop Weapon
This Halloween I was on a tighter budget, I tossed this costume together for about 20$. The focus of this instructable is the weapon. I did a few sketches and came up with what I think is the ultimate slasher movie type weapon! I made it a bit oversized for dramatic effect!
Step 1: Sketch and Cut
On 1/4" poplar, I roughed out my design, I used a scroll saw to cut two blade sides out of 1/8" MDF and scales/ handle out of 1/4" alder.
Step 2: Glue, Clamp and Sand
I used high strength wood glue to adhere the wood parts together, clamping them in place. After the piece cured I cut and sanded the profile smooth and marked a center line for the blade. I then sanded and filed the slope into the blade, rounded the handle and formed the rear spike. I added notches and wear marks in the blade to give it that heavily used and custom made look.
Step 3: Prep and Paint
I used some body filler to touch up some gaps in the blade area, I then taped off the handle area, primed and painted the blade areas. I used a combination of crumpled news paper and sponge brush to achieve the random rust pattern on the blade. I then mixed different colors of red and layered them on the different areas of the weapon. I then stained the handle, added the brass pins and wrapped the handle with aged leather. I fixed the leather in place with high heat hot glue.
Step 4: Final Thoughts
I'm really happy with the way this turned out, super creepy and really inexpensive. I have entered this project in to a few contests, if you enjoy my work please vote! thank you for looking!
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    If you were walking in a cornfield and you turned around and saw that mask disappear into the corn, that would be terrifying!! PLEEEASE make the mask.
    Have you posted an instructable for the mask? If not, you should.
    I have debated making another mask, I did the first one kinda fast and there was a lot of trial and error. I was not sure how it was going to turn out so I did not document the process properly. if enough people ask then I will, thanks for the input!
    Very nice. The mask and blade go together perfectly. But really I wanted the mask instructable more than the blade.
    looks awesome , keep on making things like this
