Introduction: The Ultimate Robot Costume
Impress everyone in your neighborhood with this awesome costume. Its easy to make and doesn't cost that much, but the results are amazing!
NOTE: You should read through the whole instructable first before actually making it. That way, you can make any changes to the design to make it your own.
Step 1: Materials
Required:
-Duct tape (strong)
-Big Box (for body)
-Smaller Box (head)
-3 dryer vents (as long as your arms)
-strong scissors
-2 cans of Spray Paint (body)
-pencil
-newspaper
-thin, tall box (for candy)
-strongish string
Optional
-Masking Tape
-1 small size spray paint (accents)
-compass
-Duct tape (strong)
-Big Box (for body)
-Smaller Box (head)
-strong scissors
-pencil
-newspaper
-strongish string
Optional
-Masking Tape
-compass
Step 2: Preparing
With the box upside down, with all the tape off (so both ends of the box are open). (Picture 1)
Cut all four flaps off the bottom of your costume. (Picture 2)
Flip the box back over, and cut the front and back flaps on the top off. (Pictures 3 and 4)
Step 3: Planning
Draw the pattern shown on Picture 1.
To do this accurately follow the steps on the other pictures.
Step 4: Cutting!
Cut on the lines you just made. Now you should have something similar to Picture 1.
Now draw a shape to let your head and shoulders through, and cut it. (Picture 2)
Step 5: Tape
Tape around your cuts for padding
Step 6: Attach the Candy Box
To attach the candy box:
Put the candy box inside the body box. Make sure that it is aligned with the top of the body box. (Picture 1)
On the bottom of the candy box, punch two slits for tape to go through. (Picture 2)
String the tape through the slits, making a tight loop around the candy box, securing it to the big box. (Pictures 3 and 4)
Step 7: Shoulder Straps
To make the shoulder straps:
String the tap through the same hole as the candy box tape. (Picture 1)
Pull the tape though the inside of the box, and fold the tape in half where the straps are to be. (Try to leave jest enough space to let your arms in comfortably.) (Picture 2)
Tape the rest of the tape back around the box (pic 3)
Now, on the top of your box (picture 4), tape two pieces of duct tape sideways. (pic 5)
Now tape two diagonal pieces there as shown in picture 6.
Tape one last piece of tape underneath where the shoulder strap connects to the top. (pic 7)
Do this to both sides.
Step 8: Cut the Candy Hole!
Trace a circle that is the width of your dryer vent. (Picture 1)
Cut this circle out. (Picture 2)
If you haven't already cut through the candy box, then do so. (Picture 3)
Step 9: Spray Painting
Put tape to cover all the rips/tears
Draw the areas you want as accents (Picture 1)
Set up an area for spray painting and spray paint the box in the general area you want to be accented (with the accent colored paint). (Picture 2)
Wait until the paint dries and put masking tape in the shape of your design. (Pictures 3 and 4)
Tape the top flaps of the body box together. (Picture 5)
Find a head box that will fit, and cut the holes for your eyes. (Picture 6)
Tape this box down, and cut wherever you need to. (Pictures 7 and 8)
Now spray paint the whole thing with the body paint. (Picture 9)
After the paint dries, peel off the tape (if you put any) (Picture 10)
Italics = optional
Italics = optional
Step 10: Attach Arms and Candy Chute
Put tape on the pointy parts of the dryer vents.
Stick one dryer vent into the candy box. It should fit if you traces your circle. If it is two loose, tie it on.
Tape/tie the loose end to the head box.
Take 2 dryer vents. On both of these, cut a hole on one end. (Cut this hole where the tape is.)
Poke two holes on either side of the body box, just underneath the arm hole.
Tie the arms to the box, using these holes.
Step 11: Done!
Add whatever decorations you want, and then you're done!
Make sure to tell everyone to put candy in the chute!
