The Ultimate Tarp Survival Shelter/Backpacking Tent by OldShotgunYoungShooter
Featured
camping crazy says: Feb 7, 2013. 11:44 AM
I do this all the time I put a guy line on the pole so I can close it up. Nice instructable
solitary man says: Feb 1, 2013. 6:30 PM
Very nice tarp set up, I may use this in the near future. Best Regards. :)
Mr.1911 says: Apr 17, 2012. 3:08 PM
Wow, this is one of the best tarp shelters I've seen! 5 stars!
l8nite says: Mar 29, 2012. 9:35 PM
pretty cool pup tent
OldShotgunYoungShooter (author) says: Mar 30, 2012. 6:11 AM
Yep. The only problem is that it's pretty heavy.(4-3) pounds
panzerfaust379 says: Apr 15, 2012. 6:12 PM
Open up a few heavy trash bags, duct tape them together & reinforce the edges every few feet with duct tape for some grommets or tie downs. use it till it falls apart. cheap, easy and light weight.
mtleising says: Apr 8, 2012. 6:11 PM
you can reduce the weight by using tyvek, very light, strong, and water proof. hardest part is buying it, you can buy it in huge rolls at places like home depot or lowes, but some people sell it in smaller individually cut peices. it is loud (crinkle noise) in the wind, although you can wash it to help that. tyveck is very cool stuff.
OldShotgunYoungShooter (author) says: Apr 8, 2012. 7:26 PM
Yah, the only problem I has was that I could not sew grommets into it.
l8nite says: Apr 8, 2012. 8:14 PM
another recent "ible" used the top of a plastic bottle to make grommets but you can also make tie points by placing a rock on the underside of your tarp and tying the cord around it from the top
mtleising says: Apr 9, 2012. 4:46 AM
yea, gonna be making a new one pretty soon, hopefully i'll be able to make one with no grommets needed. i'll post it when i'm done on here if i'm proud of it
OldShotgunYoungShooter (author) says: Apr 9, 2012. 3:37 PM
Good luck. Don't give up on the first try. : )
panzerfaust379 says: Apr 15, 2012. 6:06 PM
Been using something like this for years up in the mountains of western Maryland. I carry two three foot lengths of 3/4" polyvinyl water pipe with a coupling cemented on the end of one. Makes a 6 ft pole and has other uses.
Taufik Lone says: Apr 13, 2012. 8:00 AM
That caused the Title is SURVIVAL SHELTER,,,, :)
anyway,, good idea OSYS,, thx for shared
urtlesquirt says: Apr 12, 2012. 12:54 PM
(removed by author or community request)
OldShotgunYoungShooter (author) says: Apr 12, 2012. 2:38 PM
What do you mean. Do just not like this project or are you having problems?
urtlesquirt says: Apr 13, 2012. 5:57 AM
oh nothing, I was just kidding. its pretty nice.
KJ4ZVQ says: Apr 3, 2012. 6:25 PM
Could you, if for say you dont like sleeping with the wooly-boogers, take the 2 front stakes when your in it and pull the "door" shut? just a suggestion :)
OldShotgunYoungShooter (author) says: Apr 5, 2012. 9:59 PM
No, I hate to say, because those two stakes create the tension wich holds the whole thing up. Just 2 days ago I slept in this shelter out camping. To keep the wind out I used a 4x8 tarp staked in front and pulled over the entrance with a rope to create a rain fly type thingy. If you want to be completely protected I suggest buying a tent. ; )
mbreukel says: Mar 31, 2012. 1:53 AM
looks pretty nice!
there are other ways to make a 1 person tent with a 3x3 tarp, with or without a pole inside the tent(suspended on a line). then you have a possible door so you can close the tent.
havent tried it myself, cant find a decent english instruction, but this is how it will look.
http://postimage.org/image/5vxae2713/
the loose flap can be closed as a door.
OldShotgunYoungShooter (author) says: Mar 31, 2012. 8:26 AM
That looks pretty complicated. And when you said 3 by 3, is that in meters?
mbreukel says: Mar 31, 2012. 8:32 AM
yes its in meters.
i found a image of the folding lines, perhaps that can help. its in dutch but i think you can figure it out pretty much.
http://postimage.org/image/m712lg39z/
green lines are outside folds, purple lines are inside folds. the dots are connection points(you need 19 for the tent) the yellow line is a guy line for the opening.
if you print the image you can fold it in small, to get a bit of the touch for building it.
OldShotgunYoungShooter (author) says: Mar 31, 2012. 9:46 AM
I wonder if it will work with an 8 foot by 8 foot tarp. Just so you know my measurements are in feet. I will attempt this shelter. What part of the world are you from?
mbreukel says: Mar 31, 2012. 10:13 AM
i think it might work, but it would be smaller. the dimensions are still the same.
im from holland, europe
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
