3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Ultimate budget ($8.20) Fog Chiller
Step 5Think, measure, think, measure again, cut.
It's time for you to decide where you want your chilled fog to exit the chilling box (keep in mind the entrance will be on one of the narrow sides of the box). Take one of the couplings and trace a circle there.
Next, take the other coupling and measure a circle near the top of the box. Line up the top hole so that the opening faces into the box the long way. Remember you want the fog to touch as little as possible for as long as possible to allow for maximum mixing with air, and maximum fog production.
Cut out your marked circles, remember cut inside the lines to stop from cutting too much. Another tip, a hot soldering iron is extremely practical to cut through thin plastic. Just don't breathe in.
Insert the couplings, and try to keep them as flush on the inside as possible.
Lastly, seal up the holes with hot glue. Sealing from the outside, and then from the inside makes the process much simpler.
I know, this step is almost too documented in relation to the others. But I figured this one was easiest to show through photos.
3 comments
Oct 4, 2009. 3:39 PMBadTable Manor says:
It's probably right in front of me and I'm not seeing it: what size is the coupler?
Oct 18, 2009. 3:05 AMNastySpill says:
It looks to me like 2" (50mm)
Aug 17, 2009. 9:02 AMjimmidd says:
Would it make sense to use a male adapter instead of a coupling? you could put the threaded end inside the box, and secure with a conduit nut on the inside and outside
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Negafen
