The Ultimate didgeridoo Guide.
I was really surprised to don't see more stuff about didge-making.
It's easy and cheap, and didgeridoo is an amazing instrument, so why do make your own?
I will learn diferent way to make diferent kind of didj :
_Travel-Didge, it's in PVC, cheap, easy to make it, tunable and compact.
_Slide-didge, in PVC also, you can tune it when you play, really really nice!
_Agave/Pita, with Sandidge method, and digging method.
_How to make a nice mouthpiece.
Enjoy!
Step 1Travel-Didj
Travel-Didj
Construction of Travel-Didge.
Material:
_1 PVC tube 50 cm, diameter 32mm
_1 PVC tube 50 cm, diameter 40mm
_1 PVC tube 50 cm, diameter 50mm
_2 Fitiing 32/32
_2 Fitting 50/50
_1 Fitting 40/40
_1 Adapter 40/30
_1 Adapter 50/40
_Tape
_a small saw
Then, the Travel-Didge is a didgeridoo which is removable in 6 parts, which is tunable from 6 different ways, and once placed, can measure more than a 60 centimeter.
It is perfect to travel, you canputitin your bag, and it don't fear the Sun or humidity.
And it's sound really nice
So first, we'll cut our first tube of 32mm in 3 parts, a portion of 5 cm, some of 18cm, and part of 20cm. Isolated part of 5cm, it will be for the mouthpiece.
Don't touch the tube of 40mm.
As to the 50mm tube, cut it into 2 parts, a portion of 20 cm and the other 30 cm.
If you have a heat-gun, you can heat the part of 20cm and put in glass-bottle of boiling water, to give this last part has a shape of a bell.
Now, you just have to assemble it all, if some connections are a bit large, put tape on the tube is inserted.
As far as the mouth, you can shape it with beeswax.
Decoration:
_Papier Glass
_White paint Spray
_Paint
Exactly in this order, you should leave.
2 comments
Sep 5, 2011. 9:33 AMshortdiesel says:
I'm lazy SO instead of beeswax (which is expensive) I just used some soft silicon ear plugs (for swimmers ear) that you can find in local drugstores.  I molded it and it seems to work just fine. Time will tell if it holds up.
Jul 8, 2009. 9:29 PMfinfan7 says:
I made one out of a yucca years ago. It wasn't bad but wasn't great either. We used a drain snake on a drill to clean out the inside. Worked pretty quick.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:pedro8
