Step 1Travel-Didj
Material:
_1 PVC tube 50 cm, diameter 32mm
_1 PVC tube 50 cm, diameter 40mm
_1 PVC tube 50 cm, diameter 50mm
_2 Fitiing 32/32
_2 Fitting 50/50
_1 Fitting 40/40
_1 Adapter 40/30
_1 Adapter 50/40
_Tape
_a small saw
Then, the Travel-Didge is a didgeridoo which is removable in 6 parts, which is tunable from 6 different ways, and once placed, can measure more than a 60 centimeter.
It is perfect to travel, you canputitin your bag, and it don't fear the Sun or humidity.
And it's sound really nice
So first, we'll cut our first tube of 32mm in 3 parts, a portion of 5 cm, some of 18cm, and part of 20cm. Isolated part of 5cm, it will be for the mouthpiece.
Don't touch the tube of 40mm.
As to the 50mm tube, cut it into 2 parts, a portion of 20 cm and the other 30 cm.
If you have a heat-gun, you can heat the part of 20cm and put in glass-bottle of boiling water, to give this last part has a shape of a bell.
Now, you just have to assemble it all, if some connections are a bit large, put tape on the tube is inserted.
As far as the mouth, you can shape it with beeswax.
Decoration:
_Papier Glass
_White paint Spray
_Paint
Exactly in this order, you should leave.
Travel Didge.AVI7 MB| « Previous Step | Download PDFView All Steps | Next Step » |
Add Comment
