The Ultimate didgeridoo Guide.
Step 2Slide-Didge
Slide-Didge
Construction of Slide-Didge.
Material :
_1 PVC tube 70 cm, diameter 32mm.
_1 PVC tube 1m, diameter 40mm.
_2 fitting 40/40.
_1 fitting 32/32.
_oil/lubricant
_neutral silicon.
The Slide-Didge, can be played like normal Didj, but it can also be played like a slide trombone, that's mean, you can change the tune when you play! And that's mean also that you can tune it perfectly to play with somebody else.
So it's really easy to makeit, you have just to put the 1st tube in the 2nd tube, putting oil in the first one, and after silicon to make the junction beetween tubes. Like this, your 1st will not be glued by silicon.
Wait one day foritto dry.
And now you can make the decoration like for the Travel-Didge, anduse fittings to do like grip, like in the photo.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:pedro8
