3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Useless Machine
The Useless Machine
This is a fun machine I made that does a completely useless task.
!!WARNING!! This is a very dangerous project due to high voltages, I'm not liable for damage to property, injury, or death.
The circuit for this project is designed for a 120 volt outlet.
How it Works:
First, you drop the ball onto one of the ramps. When it reaches the bottom, an IR emitter/detector "sees" that it is there and sends 5 volts to the base of a transistor, which in turn, trips a relay. When the relay trips it dumps energy from high voltage capacitors into a coil, which works like a coil gun, and shoots the ball back up to the first ramp. Then the process repeats.
Video:
Sometimes it triggers more than once because it doesn't have enough "umph" to get the ball all the way up the tube. More capacitors would fix this.
Upgrade:
I made a rather lame attempt at making this look nicer, to see how skip to step 12.
Step 1Parts/Tools List
Parts:
  1/2" thick pine
  3/4" thick pine
  Lots of magnet wire
  (1) Metal ball
  (1) Wire coat hanger
  (1) Tube with an inner diameter slightly greater than that of your ball
  (1) 1n4001 diode (or similar)
  (1) 1n4004 diode (or similar)
  (1) QRD1114
  (1) 2n2222 transistor
  (1) 10 K ohm resistor
  (1) 470 ohm resistor
  (1) 2.3 K ohm resistor
  (1) 7805 regulator
  (1) 12v relay with one normally closed switch and one normally open switch, it should be rated to handle at least 250v
  (4) High voltage (around 200v) electrolytic capacitors (such as those found in camera flashes and PC power supplies)
  (1) 100w light bulb and holder
  (1) Bridge rectifier
  (1) 12v wall wart or power supply
  (1) Outlet plug
Tools:
Drill with drill bits
  Table saw or router
  Soldering iron
  Solder
  (optional) dremel
13 comments
Nov 16, 2010. 11:58 AMJodex says:
This is actually very nice! I'd propably make one, but power from the mains turns me back (*sad*). I don't trust myself enough. You're gonna get my vote!
Nov 16, 2010. 7:29 AMYandle says:
awesome!
Nov 11, 2010. 11:46 AM_-MacGyver-_ says:
lol pretty sweet
Nov 6, 2010. 5:34 AMfozzy13 says:
I love the concept, and was only put off by the appearance of version 1, however version 2 looks great!!
Oct 31, 2010. 8:06 AMhg341 says:
OMG i love this
if i didnt have like 10 other projects im doing
i wolud do this
Oct 30, 2010. 9:17 AMstratos13pao says:
really great
it would be thougth even beter if you change the appearence
Oct 26, 2010. 5:44 AMGreasetattoo says:
GREAT, I love it!
The magnet ball shooter, would work great in a longer running rolling ball sculpture!
Oct 29, 2010. 3:53 AMKryptonite says:
That's a brilliant use of a day! I'd love to see what you can do in a week!
Oct 25, 2010. 5:15 PMzack247 says:
is this much like a coilgun?
Oct 25, 2010. 8:43 PMbudsiskos says:
if you could give this little guy a face lift this would be an awesome sculpture!!!
Oct 25, 2010. 4:12 PMrimar2000 says:
It is interesting!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:trumpkin(Hacker's Workbench)
