3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Very Rigid $45 Eight Foot Workbench
Your shop needs a good workbench. It needs to be rigid so you can trust it to hold any project you are doing. It needs to be big so you have room to work. It needs to be inexpensive so you have more money for tools.
I built this bench for under $45 using all new materials in the spring of 2011. The top is eight feet long and two and a half feet deep. The shelf is full length and one and a half feet deep. The tool ledge is three and a half inches deep.
Note, this Instructable will use the US standards: inches are marked as ", feet are marked as '.
Materials list
Description. Qty
2"x4"x8' (nominal size) 7
1"x6"x8' 1
4'x8'x3/4" particle board 1
Box 2" exterior wood screws 1
Bottle of wood glue. 1
Tools
Necessary
Drill
Screwdriver
Saw (hand or power)
Measuring tape
6" clamps
Good to have
Level
Post level
Corner clamps
Large square
Drill guide
Countersinking drill bit
Workmate style clamping table
Larger pieces of cardboard
Rubber mallet
Step 1Step 1 At the Lumber Yard
The 4'x8' panel can be particle board, MDF, or chip board. I chose particle board as a good compromise of cost and durability. Buy from a lumberyard or big box store that will do free cuts with a panel saw. Have the store cut the panel lengthwise at 30". Panel saws do nice straight cuts if the operator is even minimally competent. Not only will this result in a better cut than you can make with a portable saw, but it will also make the parts lighter to cary and easier to maneuver.
17 comments
Mar 13, 2012. 7:10 PMthe_howlermonkey says:
Thanks for this instructable! I used your basic design for my workbench... which is about 3/4s done now... (ran out of screws, of all things) I have spent UNDER $45 in wood though! I bought a big solid core door from the local Habitat for Humanity Restore for ~$20... It isnt as pretty as a clean piece of wood, but it will do the job. The bad part is, I have spent ~$100 on clamps, and assorted bits and pieces to do the job. :) Wife wasnt too happy. I am anxious to see how it turns out. I am very much the amateur, and I cant imagine I have the legs on even... I bought some cheap levelling screws at Lowes to try to offset both my failures with precise measuring/cuts, and my horribly uneven basement floor.
A tip for any others out there who are starting from the ground up, and lack the clamps (as I did).... If you can afford the nice ones at Lowes, more power to you. I was trying to keep costs down, so I went to Harbor Freight. I have had some bad experiences there, but figured how bad could they mess up some C -clamps. So far, I havent been disappointed.
Apr 2, 2012. 11:40 AMthe_howlermonkey says:
I really like the "shelf", it gives me a whole new place to lose my measuring tape!
Nov 10, 2011. 1:53 AMBushie says:
Neat job, there...
I used the same sort of particleboard for a bench top here, a few years ago now ~ except that after cutting the 8' x 4' board into 30" and 18" widths, I glued, screwed and nailed the narrower piece along the front to give a double thickness top with a 12" wide shallow "tool well" along the back..
The top was then sealed with a few coats of a semi-gloss water-based acrylic clear gloss finish for decks..
I then tacked a 6' sheet of external-grade Masonite along the front half of the benchtop to protect the surface from impact, cutting, etc. If I was doing any serious metalworking, I might consider adding a sheet of steel plate on top, as well..
My bench top has already stood up to a couple of decades of use and abuse - mostly general woodwork, and some household maintenance - and is still going well...
Sep 21, 2011. 8:22 AMdimtick says:
very nice simple design.
I think the only change I'd make is that I wouldn't glue on the top so that it can be replaced when it gets beat up.
Oct 6, 2011. 12:38 AMksexton1 says:
Your comment about $6 for another sheet of particle board is making me want you to give a price breakdown. I only have the 2 big hardware stores around, and I'm seeing OSB, particle board, and plywood as the only options in 4 x 8 sheets. The 3/4" particle board is about $20, even 3/8" for a cover layer is $16+.
Sep 22, 2011. 7:29 AMdimtick says:
Thats a great idea to do a double layer top. i hadn't thought of that. thank you. for my projects (furniture refinishing), the biggest theat is something nasty getting spilled (like paint stripper). can't have anything like that getting onto the whatever i'm working on. i think a thin sacrificial top, like 1/4", would work well for my needs.
the way you have yours screwed, every 6-8 inch's, you don't need to worry about dropping a small engine block. i don't know the length of screws you used but as long as you have at least 3/4" bite (at least as much bite as the width of the wood going thru ), then you don't need to worry about pull out.
you may want to add another 2x4 along the front edge of the shelf, below the shelf edge. the 2x4 the runs on the back of the shelf adds some stiffness but i'm not sure if it's enough. i can't tell from the pictures but you should screw thru that back shelf 2x4 into the table legs. you have plenty of rigidity in the short direction because of the your framing but i don't think it's enough in the long direction. you may want to add some diagonal braces onto the legs. you can also simply screw it to your wall.
another thought. a simple thing to get some more function out of your bench you can drill a grid of evenly spaced 1" holes that will allow you to use bench dog clamps simpilar to that little folding work table you have.
i love these things
http://www.amazon.com/Bench-Accessory-Kit-Dogs-Holdfasts/dp/B001DSXLTK/ref=sr_1_23?ie=UTF8&qid=1316699885&sr=8-23
Sep 21, 2011. 5:54 PMjongscx says:
Your "This is in US standards" comment made me wonder...
How do they sell wood in countries that use metric standards? Are they still 2x4s?
Anyway, nicely made. Was the bottom shelf a "Measure twice/cut once" scenario or was that on purpose?
Sep 24, 2011. 12:53 PMjkm says:
although in metric, over here in The Netherlands lumber is still measured in multiples of 25 millimeters, i.e. Inches. So a 4x2 would be 50 x 100.
If rough sawn, that would be about the actual dimension. If planed smooth, it would be 44x94. Which would be sold as such, and not as 50x100. Lengthwise, we usually have lumber in multiples of about 30 cm, starting with 180 cm/ 6 feet. For sheets of ply etc, we're just about moving form 4"x 8" (122x244 cm) to 125x250 cm. But you will find both sizes, it's a global market.
Sep 21, 2011. 10:19 PMCelt says:
I got an oscillating tool for my b-day recently. at first I wasnt sure what i would use it on, but i have found it to be the most useful and fast tool in my "shop". Great bench BTW, i think i shall model mine after this one, with a few minor adjustments of course.
Sep 22, 2011. 8:28 AMvincent7520 says:
nice !
never saw a tool ledge as is … it's a great idea !…
Sep 21, 2011. 7:49 AMdoctormerlin says:
Great design: simple, efficient use of materials.
Nicely laid out Instructable!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:pawelski
