The Vex Assault Vehicle
910
16
5
Published
Introduction: The Vex Assault Vehicle
We are going to build an Assault Vehicle using Vex robotics and a Rival MXVI-4000.
Step 1: Step 1: Materials
- 1 (Nerf Rival MXVI-4000)
-1 (VEXnet Joystick)
-1 (VEX ARM Cortex-based Microcontroller)
-2 (Angle 3x3x25)
-4 (Standoff 2.00")
-8 (Nut 8-32)
-13 (8mm spacer)
-2 (Linear Rails)
-7 (Bearing flats)
-13 (4.6mm spacer)
-24 (Bearing Pop Rivets)
-6 (Screw 8-32x0.500")
-2 (Linear Slide)
-1 (1x5x1x25 C-Channel)
-3 (2 wire Motor 393)
-3 (Motor Controller 29)
-4 (4" Omni-Directional wheels)
-2 (4" High traction wheels)
-6 (60 tooth gear)
-2 (84 tooth gear)
-2 (60 tooth High strength gear)
-26 (Shaft Collars)
-20 (Screw 8-32x0.250")
-3 (1x2x1x35 C-Channel)
-1 (Angle 2x2x25)
-2 (Pillow Block Bearings)
-2 (Standoff 1.00")
-4 (Standoff 0.50")
-2 (Rack Gearbox)
-4 (1x2x1x25 C-Channel)
Step 2: Step 2: Base
Step 3: Step 3: Base
Step 4: Step 4: Finished Base
Step 5: Step 5: Drive System
Step 6: Step 6: Drive System
Step 7: Step 7: Finished Drive System
Step 8: Step 8: Cross Beam
Step 9: Step 9: the Attachment of the Base
The pillow block bearings attach the base to the drive system.
Step 10: Step 10: Cross Beam
The cross beam adds more support.
Step 11: Step 11: Finished Drive System/ Attached Base
Step 12: Step 12: Finished Base With Rival MXVI-4000
The base is important because the linear system, which shoots the Rival MXVI-4000, sit on top of the base.
Step 13: Step 13:
This will insure you build around the Rival MXVI-4000 so it does not jolt when driving around.
Step 14: Step 14: Linear System
Step 15: Step 15: Linear Drive System
The Linear drive system is in charge of shooting the Rival-MXVI-4000.
Step 16: Step 16: Shooting Mechanism
Step 17: Step 17: Finished Shooting Mechanism
Step 18: Step 18: Attachment of VEX-ARM Cortex-based Microcontroller
Basically the brain of the robot.
Step 19: Step 19: Fastening Wires
It is imperative to fasten your wires unless you want them to get caught, and be jumbled all over the place.
Step 20: Step 20: Finished Vex Assault Vehicle
Congratulations you did it!
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
    5 Comments
    what's the construction kit used for the main build? it looks like a version of meccano and who distributes it?
    it is a vex edr kit you can get them here
    https://www.vexrobotics.com/vexedr/products/view-all/?ref=tile
    Awesome. If would be so much fun to unleash a bunch of these at the same time.
