Introduction: The Victorian Sound-Tube...A Steampunk Mp3 Player
Picture of The Victorian Sound-Tube...A Steampunk Mp3 Player
The Victorian Sound-Tube is a Steampunk Mp3 Player with motorized holding Arms and Sound to Light Control. The Tube lies on a Holder and two Arms of Brass are holding the Tube from both Sides. Put a Switch and the Arms separate the Tube.
Step 1: Lets Go..
Picture of Lets Go..
First we need a Musicman Ma Mp3 Player. On Ebay for small Money ;)
Lampholder Arms, Coppertube 60mm, Ballscrews,Micromotors,Sound to Light Control for Cold Cathode Lights, Cold Cathode ( Blue with Inverter),Threaded rod, Hot Glue, Switches and Batterys, Endswitches
Take the Electronics from the Housing of the Musicman. Be carefull, there are thin cables in it and ground please once ! Solder 2 Cables on the On/Off Switch from the Musicman to Control it later from outside the Tube.
Now we take a Coppertube and drill holes where also the buttons are from the Musicman. I soldered smal Brasstubes as guidance for the Buttons. ( Second Pic ). I used old Lampholders for the Speakerhousing. Cut them and take ventilation screens from the building market. Stick it together. The Speakers from the Musicman fit in exactly (Pic 5 ). Put the Electronic inside the Coppertube, fix it with Hotglue. Now by the before drilled holes we push from above ball-screw inside as tracers. Now build everything together ( Pic 6 ) and you got an Mp3 Player in a Tube. Big Sry but I have no more other pictures !!!
Step 2: The Housing
Picture of The Housing
Take Beach Wood or Poplar and build the shape of the housing depending upon your fantasy. Paint it with Woodcolor.
Solder a Holder for the Soundtube as in the second Picture. It goes also differently. Important is, the Tube has a good lying Position. I made an half shell from the same Coppertube and paste it with Black velvet.^^
Step 3: Inside the Housing
Picture of Inside the Housing
Inside the Housing there is sitting the whole Mechanics and Electronics. In order to let the Arms move to left and right, i take 2 Micomotors.Connect with a threaded rod. At the Start and Endpoints there must be sitting an Endswitch. The Endswitch must after lengthen push way to be aligned.
Step 4: Finish
Picture of Finish
After the assembly it looks then in such a way. This Project i made in November 2014. Two Weeks work.
I hope you like this Instructable :)
Best Regards
Leander Lavendel
DuaneJ1 (author)2016-02-20
Hi I was wondering where do you get the micro motors from? And the gear/linkage? Very cool project by the way.
Leander Lavendel (author)DuaneJ12016-02-21
Hi DuaneJ1,
the Gears are from old Clocks and the Micro motor from Amazon or Ebay.
http://www.ebay.com/itm/DC3v-6v-20mm-long-shaft-10...
The drive to the threaded rod is self made. ;)
DuaneJ1 (author)Leander Lavendel2016-02-21
Thanks for the quick reply. I have been looking around for the Lampholder Arms that you used, looks like the only place I can get them is from USA. Is there any other place closer to Europe even if it's in china that they can be sourced from?
Many thanks!
jimmysymo (author)2016-01-02
VERY WELL MADE, I like your works ..DO YOU SELL any of your works of ART ?
Thanx,
sure i sell some of my Objects. Visit my Homepage and write a E-mail if you want ;)
http://www.kupferkeller.de
BruceE3 (author)2015-04-03
cool!
bricabracwizard (author)2015-03-29
Excellent build! Were the lights already with the MP3 player?
@ bricabracwizardbricabracwizard
Hi,
no, there are two Switches to control the Lights. One turn it off/on and one turns the Beatcontrol ;)
Grunambulax (author)2015-03-26
you are a genius
msimes (author)2015-03-24
looks absolutely awesome. how do you power / charge the mp4
msimes (author)msimes2015-03-24
*MP3
Leander Lavendel (author)msimes2015-03-25
Hi msimes,
at the Bottom of the Tube there is a Connection to charge it. 4 Hours and Akku is full ;)
sperry18 (author)2015-03-24
Beautiful
cashwood (author)2015-03-24
Very nice build!!
About This Instructable
7,520views
258favorites
License:
Bio: Hi, i am a Steampunk Artist from Germany. You have Questions? Write me, check out my Homepage or meet me at Facebook.I look forward ... More »
More by Leander Lavendel:A Talking Steampunk Thermometer"The Time Cup" - A Steampunk Timer/Clock with Westminster SoundThe Pillars of Time - A Steampunk Nixie Clock
Add instructable to:
