I made it easy for you, skip all this reading nonsense and watch the video-
http://www.metacafe.com/watch/726501/build_your_own_wart_remover
A doctor visit means sitting in the waiting room for a half hour and having to pay a hefty bill for something you could easily do yourself. Doctors use either
Liquid Nitrogen~ -320 F or
Dry Ice~ -110F
to remove warts.
We're going to use the liquid from dust remover cans which is anywhere between -25 and -160F
Before commenting, I know, I know there are many ways to remove your own warts. Duct tape, onions, vinegar, k'nex, banana peels, etc. But why do those when you can be awesome instead and do it like the pros?
On that note, if you've got any other original wart removing ideas, I'd love to hear them.
Remove these ads by
Signing UpStep 1Get the materials-
One can of airduster/ spray dust/ dust off/ compressed air duster etc.
One plastic hollow Q-tip (or "cotton bud")
Scissors
A wart
If you don't have hollow q-tips, you can use the straw from the airduster, a square of toilet paper and a twist tie to improvise.
Global warming isn't caused by us, It's been around since the earth's beggining...
Globabl warming has been happening since Earth's formation, It's not being caused by us
B) Global warming is completely unrelated to CFCs. Pick up a book, FFS.
Cl· + O3 → ClO· + O2
ClO· + O3 → Cl· + 2 O2
Source: Wikipedia
I actually just came here to get the information about the temp. of liquid nitrogen vs. CO2 vs. Dust Off, but ended up reading the Instructable anyways. I had a wart removed by the dermatologist with liquid N2 and it worked wonders! Great to see you've managed to find a way to do this for cheap.
To everyone: be careful! That stuff will freeze anything else just as well as it will freeze your wart!
I went to Walmart and bought a Dr Scholl's Freeze Away kit and tried it, but so far it hasn't worked too well.
Verucca Vulgaris is warts that commonly appear ont he hands, Verucca Plantaris usually occur on the feet (plantar warts), and are usually the infection of HPV-2 (a non-genital version of the papilloma virus; you cannot get genital warts from contact with it).
Verucca Vulgaris typically occurs between the teens and the twenties, I had one and I'm an exception because I'm in my thirties, and getting small sites of excema and this wart after being seemingly immune all this time. The wart (that I've affectionately named "Kuato" (from the movie Total Recall) has been treated with cryogenic exposure and is presumed dead. From someone with experience, and coming from a few other debates, warts DO have roots, contrary to what anyone will tell you. This is why simply cutting them off does not cure the problem.
A person's susceptibility to HPV's many strains varies widely. Some warts are resolved in a year, others stagnate, and others expand grossly out of control (thriving). Cryotherapy is usually worth it because you not only destroy it's vascular structure, but the real method is apparent a few days later: A blister forms beneath it and separates it from the normal dermal layer. When that happens, you can simply pull it off your skin, roots and all. All that is left to heal is the same as a 3rd-degree burn.
Don't be fooled, it will scar, but the scar is very superficial and will likely be hardly-noticeable after a few years, but will never truly disappear. The cryotherapy method is causing intentional and controlled frostbite, which actually causes your own body heat to cause a burn on your skin. Cauterization therapy (burning it off) does not destroy the maligned cells as well without a deeper scar, which is why cryotherapy works better.
"Cryo-burns" are instant and destroy tissue on contact. Use the above provided link for the less-painful method using duct-tape. This chokes the skin of oxygen, and can work in as little as a month. If you've ever had a band-aid on your foot and worn shoes over that for a day, you know the sight of the white, asphyxiated skin around that wound.
I had to walk on the front of my foot for a week : /
They're still getting treated.
