The Washing Machine with a yo-yo
 by Doctor Popular
Featured
The Washing Machine is one of my oldest tricks, but it's still one of my favorites. I get a lot of requests for this one, however very few yo-yoers actually know how it's done.
The trick itself can look very intimidating but trust me, it's totally doable by any intermediate player.
The trick; a yo-yo starts attached to the string (like most yo-yos are) but is removed from the string and popped into the air before being re-attached... All while the yo-yo is still spinning.
I have attached a video demonstrating the trick, check it out.
The yo-yo; Any yo-yo can be used for this trick as long as it can sleep (spin at the end of the string). I've even used a Duncan Butterfly. As with any trick, the longer the yo-yo can sleep, the easier the trick becomes. So I suggest using any decent ball-bearing yo-yo. Using a butterfly shaped yo-yo would also totally be recommended.
It's a bit tricky for me to describe some of the moves in text, especially when a step requires you to switch planes (such as required popping the yo-yo off the string, or using your thumb to put it back in the loop). So if you have difficulty on a step (or a suggestion for a description change) please let me know.
For more yo-yo info and videos you can check out www.DoctorPopular.com. Thanks Phil and Shan for helping out with the pics.
Step 1: Unwind the string
Hold the string about 3 inches above the yo-yo and untwist the string.
When the string is unwound enough you should be able to open it up with your fingers. The wider the loop, the easier it will be to do the trick. Usually about 20 spins will do the trick.
When it's ready, wind up the yo-yo like you would any other yo-yo.
IncrediblyCondensedBlackMatter says: Aug 10, 2012. 7:49 AM
Is this easiest with a certain string material? i tried to get it with my Metal Drifter on some slick-6 string, and it seems like the fibers of the string hold the string "closed" past about half an inch up the string (the string will un twist but will stick to itself and not let the strands come apart) also, should the string tension be particularly low, and should i use newer strings?
kthekiss says: Nov 10, 2008. 6:36 AM
wow, dude! i went to your site and you are multi-talented! way to go!
napalm008 says: Apr 6, 2008. 1:36 PM
what kind of yoyo is that it's pretty good.
Doctor Popular (author) in reply to napalm008Apr 6, 2008. 2:45 PM
It's a Bolt. Available from DocPop.orgDocPop.org and from DoctorPopular.comDoctorPopular.com
higgrobot says: Feb 24, 2008. 10:21 PM
All I could see was eggs, there must be something wrong with me
DELETED_freewheeler says: Aug 17, 2007. 8:00 AM
(removed by author or community request)
Doctor Popular (author) in reply to DELETED_freewheelerAug 17, 2007. 11:27 AM
It's a combination of things; a decent ball bearing yo-yo, refined throw, and smooth execution of the trick. Most yo-yos are ball bearing these days.
dartman says: Mar 3, 2007. 8:40 PM
nice trick, nice yo-yo to what is it a viper? i have the coral snake and it rulez
Doctor Popular (author) in reply to dartmanMar 4, 2007. 5:11 PM
It's a Bolt Yo-yo.
dartman says: Mar 3, 2007. 8:44 PM
btw im trying 2 learn how 2 yo-yo freehand style but idk any tricks other than the basics got any kewl ones?
dartman says: Mar 3, 2007. 8:41 PM
oh..whoops ijust watched the vid and didnt look at the photos closely until just now heh heh
mark101 says: Mar 1, 2007. 1:17 PM
still here for the people to see
Doctor Popular (author) in reply to mark101Mar 2, 2007. 12:14 AM
Thanks. It's fixed now. Safari and instructables seem to have troubles together. I had a lot of trouble deleting the image on my laptop, but it looked like it was finally off. Now I can see that didn't work. So I borrowed my girlfriends computer and it deleted right away.
Doctor Popular (author) says: Feb 26, 2007. 10:41 PM
Step 4 had a vintage picture of a nude woman in the background. It seemed to be the focal point of the comments, so I've fixed it.
mark101 in reply to Doctor PopularFeb 28, 2007. 4:42 PM
the original is still there LOL@ the orange paintjob
Romano911 says: Feb 26, 2007. 6:35 PM
I always loved watching that trick... this vid is inspiring me to practice it myself... thanks, Doc!
royalestel says: Feb 26, 2007. 6:27 PM
Definitely PRON! C'mon man . . . watch your backgrounds in your photos. It really distracting among other things . . . Otherwise a rilly great instructable. But I'm flagging it anyways . . .
mark101 says: Feb 24, 2007. 12:17 PM
PRON!
Punkguyta in reply to mark101Feb 26, 2007. 3:23 PM
No no no, you got it all wrong! It's pronounced "Pr0n".
robtsou says: Feb 26, 2007. 12:42 AM
It's not PRON, it's EROTICA! Nice instuctable Doc!
mantislee says: Feb 24, 2007. 9:26 AM
Nice trick and nice instructable...with a side order of vintage p0rn. :-)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
