Introduction: The Way to Connect Single Coler Led Strip Lights
Picture of The Way to Connect Single Coler Led Strip Lights
The Ways To Connect Single Coler Led Strip Lights
Step 1: Connect With DC Connector
Picture of Connect With DC Connector
Fit for : Led strip light With 2pin connect cable
Step 2: Connect With Easy Clips
Picture of Connect With Easy Clips
Fit For: LED strip lights without connect cable
Step 3: Connect With Double Easy Clip Cable Connecter
Picture of Connect With Double Easy Clip Cable Connecter
Step 4: Connect Single Color Led Strip Light With Switching Enclosed Type Power Supply
Picture of Connect Single Color Led Strip Light With Switching Enclosed Type Power Supply
Connect the V+ V- Of the Led strip Light and Power Supply Directly
Fit For: Led Strip Lights With 2pin connect Cabel and Switching Enclosed Type Power Supply
Step 5: Connect With One Side Easy Clip Cable Connector
Picture of Connect With One Side Easy Clip Cable Connector
Fit For: Led Strip Lights Without 2pin Connect Cabel and Switching Enclosed Type Power Supply
Step 6: Connect Single Color Led Strip With Adapter Power Supply
Picture of Connect Single Color Led Strip With Adapter Power Supply
Connetc With DC Female/Male Easy Connector
Fit For:The Connection Of Led Strip Light With 2pin Connect Cable And Adapter Type Power Supply
Step 7: Connect With 2 Pin 10mm/8mm Easy Connect Clip to DC Female Connector
Picture of Connect With 2 Pin 10mm/8mm Easy Connect Clip to DC Female Connector
ScrapMasterJason (author)2015-12-11
This might be helpful, but because you went and put your advertising logo on the exact part of the picture I am trying to see, I can't tell what the connector is or whats going on in most of the pictures. If this is your version of sharing and helping, maybe Instructables isn't the website for you. This site is not about advertising or copyright protection, it is about open source sharing.
Thanks
Thats right
About This Instructable
2,034views
11favorites
License:
Bio: LED Channel Supplier
More by TangB1:The Way To Connect RGB Led Strip LightsThe Way To Connect Single Coler Led Strip LightsHow to solve the problem of more than 10 meters single color lighting failure?
Add instructable to:
