Here I am about to start sampling some goodies off the smoker.
First a safety warning. I used old propane tanks for my cook chamber and firebox. Propane is VERY dangerous. You should seek a professional to render the tank safe for construction. Do not attempt this yourself.
Remove these ads by
Signing UpStep 1Door cut outs
The door/doors design is a personal choice. Mark and cut whatever you feel will work best for you. I elected to make two larger doors with the little door in the middle (shown cut out in this pic) so that my cook racks could be one piece, slide out, and I would have room to place a whole hog in it without fighting to wiggle it in and around a center piece.
A word of warning here. Don't be surprised if when you cut the tank things warp a bit. This is normal and not your fault. There are ways of correcting this that I won't go into now.
Once you have your doors marked you can cut them out with and acetylene torch, plasma cutter, hand grinder with cut-off wheels, or a sawzall with metal cutting blades. I have also known people to cut them out with a circular saw with a metal cutting blade. I prefer to cut with a some sort of saw as the gap is less in the cut and I don't cut a very straight line with a torch and can't afford a plasma cutter.
Another tip is to not completely cut out your door. Leave some materiel in the corners and middle of the top and bottom of the doors to keep the tank in alignment for as long as possible. You will go back and make the final cut outs later.
Thanks very much for taking the time and trouble.
Don't think water will avoid the explosion all together...Depends what is involved...Some products actually react with water.
My old employer back in RI told me once he removed the lid of a tank he supposed to weld an the tank was filled with water. He said the explosion made him almost crap on his pants when he landed on the floor on his but...When in doubt with unknown substances wash the tank well before doing stuff like like this and be very careful.
This tank welding procedure reminds me of another accident that resulted in the dead of the welder in a industrial setting in Portugal... the welder died when he was welding the lid of a bigger tank used to store a chemical component.
The explosion pushed the lid and the welder against the ceiling and the welder was crushed in the process....
Not sure if he had some common sense, but the truth is people sometimes get seriously injured and worse doing something that does not look dangerous.
Be very very careful girls and lads!!!!
1) You would need to create a least few hundred PSI to even trigger the pressure relief valve. All propane tanks have them. It's the law
2) Speaking of laws, look up "Charles's Law". You'll need a bonfire get a sealed tank, this size, full of air at zero-PSI to explode. .
3) Even if after pouring the water out, you screwed the plug back in the tank...
I'm pretty sure the hole you are cutting in the tank might let expanded air escape.
