3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Wild Pig Smoker
Step 14Firebox Air Inlet
Firebox Air Inlet
For a fire to burn properly it needs oxygen. Here we make a simple adjustable air inlet in the side of the tank. You should try to keep the top of this inlet below the firebox grate.
Mark and cut out a rectangular piece using the hand grinder with cut off wheel. Then weld a couple small pieces of angle iron vertically on each end of the opening as in the picture. I welded a couple pieces of half inch flat on the cut out piece so that it would fill the entire area and it gave a good mechanism to use as slides inside the angle iron.
Next drill a hole through the cutout piece near the top and weld a nut over this hole. You can then use a piece of threaded rod or just a bolt to screw through the cutout piece and against the tank to hold it in position.
As you can see in the picture I also welded a piece of quarter inch round on the bottom of the opening for the cutout to rest on when closed.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:purplewg
