The Wireless Internet Cantenna gets Dished
I just built this Cantenna, and I must have an addiction to the internet or something because I'm hot-rodding the poor thing.
In this, I describe how I use the Cantenna and add it to an old satellite dish.
First, you must have a Cantenna. If necessary, search for that on this site or in google.
Then, you need an old satellite dish. It might not be like the one I use here, so take a look at: http://people.wallawalla.edu/~Rob.Frohne/Airport/Primestar/Primestar.html This primestar has an easy to use feed arm. I had to improvise a method of mounting the can, because the arm on my dish doesn't go all the way to the feed-point area.
Tools were just a couple wrenches to re-configure the dish, a phillips screwdriver to rip apart the old lnb's, a utility knife and a roll of electrical tape. Oh, and an ink pen.
Step 1What the cat drug in
So I decide to build this, I drop by a friends place and grab his old dish and drive up to the shooting range. Now to see just what exactly I'm going to be dealing with.
There's a pair of LNB's on a y-adapter. The y-adapter is a two-piece clamshell plastic affair that looks rather doubtful. It looks like I'm going to have to add something to get from the arm to where the cantenna is going to go. Oh well, I'm feeling determined at this point. Besides, if I tear it apart enough, maybe something will inspire me. It's happened before
86 comments
1-40 of 86next »
Jan 21, 2012. 5:50 AMtc998hot says:
WiFi Signal Amplifier Booster Manufacturers
http://www.powermicrowave.com/
http://www.powermicrowave.com/en/4w-en.html
http://www.powermicrowave.com/2wen/2w-en.html
Sep 6, 2008. 12:22 PMSkeletel says:
Can you make this thing wireless so that it Transmits to your house so that you can surf the web in your bedroom? And how many miles will it detect the WiFi signals for?
Sep 10, 2008. 11:17 AMFoxtrot70 says:
I have one of these set up inside my house and recieve signal from a site 6 miles away. it appears to have a -30dbm gain. Not too shabby for some scrap parts! I have seen articles where folks were using 2 home cordless telephones and linking them via two surplus 10' C-band dishes and they had a range LOS (Line of Sight) of 125 miles. You can also make one heck od a "Big Ear" listening device by placing a mic in the focal point. Even though the dish is mesh you'll get respectable amplification, but a replacing the mesh making it solid or placing foil or saran wrap, I know it sounds screwy or clear shipping tape, or my personal favorite, "The Handyman's Secret Weapon...DUCT TAPE!" on the mesh this will give a solid surface to reflect from as far as sound is concerned. It can also be used as a GIANT speaker where you could place one of those Pest eliminators in the focal point and move some rodents and any thing else that has sensitivity to high frequency sound. I watch way too much Red Green.
Jun 21, 2009. 5:01 PMmarigo says:
Hi Foxtrot70, Could you tell me where did you read that article where folks use 2 home cordless phone and 2 10` c-band dish to make a link of around 125 miles from each other,do they use any can with the adaptor, any yagi antenna can you explain a little or or can you give please give us the link...I m pretty interested thanks for your patient
Jun 21, 2009. 6:55 PMFoxtrot70 says:
Hi Marigo
Try this link, It was the DEFCON WiFi Shootout
http://www.unwiredadventures.com/unwire/2005/12/defcon_wifi_sho.html
Nov 12, 2008. 1:00 PMFoxtrot70 says:
Hmmm...I do have a spare Amana Microwave oven this has possibilities!
Nov 12, 2008. 1:06 PMFoxtrot70 says:
I have just taken the LNB's out of a Dish Network 500 dish and used the gray shroud as a form and placed a bowtie antenna within with 2 ranges 2.4 Ghz and 1.9 Ghz. Again this unit is in my home office about 8' off the ground and shooting thru a 6" frame wall and the signal increases from -124dbm to -89dbm, now if I were to mount this on my roof it would have direct line of sight, should improve a little...LOL A LOT!
Sep 13, 2008. 9:21 AMSkeletel says:
Oh well.(Shrug)Thanks anyway!
Nov 26, 2008. 11:34 AMFoxtrot70 says:
If you build up the dish antenna it will get a gain of about 30db, then go to this site www.primecellular.com and purchase the inside dome antenna P/N: CM222 on sale cost $38.95 this should work for you. It works on 2 bands 806-900mhz and 1700-2500mhz with a gain of 3db. Do not place the dome antenna in front of the dish antenna the signal will produce feed back ringing, if an amplifier is in the line this will cause damage to the amp. If the signal is still weak you will need to purchase an in line amplifier. Again go to Primecellular and look for wireless amplifiers for buildings. WARNING!!! Try the dish inside first. Keep in mind when you mount your dish antenna on the outside of your house or apt. you will need to earth ground the antenna mast and the antenna coax line failure to do this WILL result in lightening damage of the amplifier and also your house! Hope this helps.
Aug 21, 2011. 11:17 AMThe Old Fart says:
Now maybe I like to make things that have been over-killed but I was thinking if I used a 10 foot dish with a 4 foot yagi attached to the cantenna and then just as an added bonus to add a 180 db gain amp.
Could I get signal from over the horizon?
Now mind you I was just thinking, which gets me into trouble a lot of the time with my wife. But could this work?
Aug 21, 2011. 5:08 PMThe Old Fart says:
This is a picture of what I am talking about. I think that it looks like a cross between a 50 cal. machine gun and a Star wars laser canon
Aug 22, 2011. 10:43 AMThe Old Fart says:
I don't understand what you mean by a "Hot Element"
I also am not sure if my picture explained it or not but I was thinking that the dish would have a broader area to receive a signal and then reflect the signal at its focal point to the yagi in hopes that it could be a bit less of pin point aiming in the direction of a tower.
Now I was only thinking that if any one of the components were able to boost the signal strength then maybe it would do a lot better if I used all of them into one unit.
On another note would it work if I used the cantenna at the back of the dish with a shorter yagi extending outward?
I am good at building stuff like computers and designing boats and I put together some really weird things that do seem to work.
But I don't understand the math that is involved with wave forms, in fact I am pretty poor when it comes to math.
So please bare with me if I seem a bit mentally challenged But I do work at trying to figure this all out.
Thank you very much for your feed back.
May 9, 2011. 9:47 PMhhamer says:
What is the range of that:?
May 6, 2011. 2:51 PMdflores3 says:
What about using a more old antenna, the first ones, does improve the range? (you know the big first ones)
Jul 29, 2009. 10:39 PMHeshBeatboxFill says:
This is my work in progress . still need to make the biquad antenna tip . and the umbrella text is shoped but the logo is painted and finished
Jul 30, 2009. 4:52 PMHeshBeatboxFill says:
thanks ...the text is gunna say Umbrella corp. ...from resident evil .but i cant figure how to stencil it the right way ...and a fractal sounds cool but i wouldnt have a clue how to tune it to 2.4gh. good idea though
Feb 9, 2011. 6:59 AMurbanpirate says:
cut the stencil in cardstock, spray it onto contact paper and cut it again. stick to dish spray and peel. for 2 colors you need 2 stencils, registration marks help as well.
Aug 23, 2010. 5:09 PMSaturn V says:
I looked at this just because of the title. Love it!!!!!
Jul 9, 2010. 4:52 PMlane29 says:
i just switched to dish aand they left me with a older one great idea
Nov 21, 2009. 4:01 PMGathrax says:
Wow, i just found this site and posted a similar project, though mine is crude and built with no knowledge of how it works, just knowing it does. I guess i should have checked to make sure there were no similar posts already. Good job on this though, im going to do some research and rethink my design.
Sep 14, 2009. 6:34 AMsal876 says:
http://urbanwireless.info has a few good tutorials on making these type's of antennas
Aug 11, 2009. 10:21 AMH3xx says:
I really like your idea to reformat the structure of your dish. Naturally, satellite dishes are designed to project all of the devices waves straight up to the satellite in space. turning the dish upside down, in my opinion, is brilliant! Not only does your dish point in the right direction, but it also makes it more compact and usable! Bravo!
Aug 11, 2009. 9:12 PMH3xx says:
Well if were designed to be perfect, it would probably be too good to be true. I'm going to use my dish to increase my cell signal. I get my internet through tethering with my phone, because I live in a pretty rural area. Not a lot of wifi connections around, and the few that are, are secured. So I'm going to try and find which direction gives the best signal and mount it in that direction. Wish me luck on that goose chase! ;)
Jun 20, 2009. 4:28 PMcx420ns says:
ahhh you rule, i'm too poor for the net right now, had to get it cut off last month. i can pick up one bar on a router somewhere nearby but it's not enough to connect. i will have to do this very soon.
Mar 5, 2009. 3:07 PMGamer917 says:
Finally i can get free internet connection anywhere in a city (So many cafes w/ free wifi)
1-40 of 86next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:Shadetree Engineer
