The Wooden Bobcat Toy
34,560
156
24
Posted in PlayPuzzles
Introduction: The Wooden Bobcat Toy
I was going through Instuctables and saw some amazing stuff.  I just wanted to do something that was just as amazing.  Hopefully I have a file you can use.  I used my Epilog laser engraver (Epilog Mini 12x24 45 watt).  This project took 12 hours to design, 60 minutes to cut out, and 30 minutes to glue together. This project is geared towards someone with access to a laser engraver or CNC machine.
Supplies:
1) 2 sheets of 12x24x1/8" of press board
2) 1/4" wood dowel 18"
Tools:
1) Super Glue
2) Razor Knife
3) Laser Engraver (ideal)
4) Corel Draw x4 (ideal)
also check out the MPG file video
Step 1: Drawing Plans
Pick or print out the file you prefer to use.
Cut out the pieces by whichever means available to you (laser engraver or CNC is ideal).
Step 2: Assembly of the Base
Here is the fun part!  It's like a puzzle.  Remember to glue the edges of the cut pieces.
1.)  Attach base-1 to base-4
2.)  Attach base-2 to the oppitsite side of base-4
3.)  Attach base-3 to the small end between base-1 and base-2
4.)  Attach base-5 to the rear of base-1 and base-2
5.)  Attach base-6 to the bottom of base-1, base-2, base-3, and base5
6.)  Attach base-7 to side of base-5
7.)  Take base-9A and place on top of base-1, base-5, and base-7 to connect all three
8.)  Attach base-8 to other side of base-5
9.)  Take base-9B and place on top of base-2, base-5, and base-8  to connect all three
Step 3: Assembly of Cage
1.)  Take cage-1 attach to cage-4
2.)  Attach cage-2 to cage-4
3.)  Attach cage-3 to the tops of cage-1, cage-2, and cage-4 connecting all three sides
4.)  Once step 3 is completed attach the cage to the base
Step 4: Assembly of the Woodraulics
1.)  Take w-1A and attach to w-2A
2.)  Attach w-1B to w-2A
3.)  Attach w-2B to the bottom of w-1A and w-1B thus creating a four sided block
Repeat steps 1 through 3 to complete the other three blocks for a total of four Woodraulics
Note: w-3 will be installed later
Step 5: Assembly of the Bucket
1.)  Attach bucket-4 to the inside nitch on bucket-2 and bucket-3.  Repeat this step for a total of four times.
2.)  Attach bucket-5 and bucket-6 to the outside of bucket-2 and bucket-3.
3.)  Attach bucket-1 to the bottom of bucket-3, bucket-5, and bucket-6.  This completes the bucket
Note:  the support arms will be addressed later
Step 6: Assembly of the Tires
The tires are fairly easy.  I used  the 1/4" dowel to line up and attach the four parts to create the tire. Be sure to overlap/alternate each part so that the end result looks like tread (see photo).
1.)  Place the dowel through the center of tire-4.
2.)  Place the dowel through the center of tire-3 and place tire-3 over tire-4.  Alternate the groves to begin creating the tread.  Glue tire-3 to tire-4.
3.)  Place the dowel through the center of tire-2 and over tire-3.  Glue them together, again alternating the groves to continue with the tread process.
4.)  Finally, place the dowel through the center of tire-1, place over tire-2, and glue them together.
Repeat steps to create four tires.
Step 7: Installation of the Tires
1.)  To create the axels, cut 1/4" wooden dowel into two 1/4" x 3.5" pieces.
2.)  Take one completed tire and glue to one end of an axle.
3.)  Slide the axel through the bottom of the base.
4.)  Take a second tire, place on other end of axel and glue.
Repeat steps to complete the second axle
Step 8: Assembly of the Bucket to the Base
now we attach the support arm to both sides of the base using the 3/8 dowls
 install the woodraulics to the bottom part of the the support arm for both sides
on top install final two woodraulics
now install the push rod(w-3) in woodraulics an connect them to the support an the others to the bucket(see photo)
look at the video to see it work mpg file
    • Slow Cooker Challenge
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    24 Comments
    This was just great to do!!!! Thank you very much.(Woodraulic loader) If you have similar projects available, i would just love to buy this from you. I am new to laser cutting, and surely have a lot to learn still!
    This is very good work, All dear , would you please if you have more CDR or DXF file for 3D puzzles Animals, Vehicles and Aircraft please send them on waleed_waheed@yahoo.com
    Thanks
    Sorry ive been so buzy design an working on other jobs
    I not have had time to do 3d puzzles
    Everyone want stickers printed an one off laser cut designs
    Soon as I have one I will send it
    Thanks it was a fun build.
    thanks im in the works of building more , made a few other prototypes
    i forgot my other account soooooooo
    Any chance for AutoCAD2000 DXF? Looks like fun to build
    I do have a DXF file is it deffrent then a auto CAD2000 DXF?
    also i have a eps file if that helps, for sum reason your having problems. let me know ill help the best i can
    Hack
    What version if AutoCAD are the DWG and or DXF created in. I have 2005 and can not open the above files that are posted.
    Thanks for the help.
    You have a laser cutter? Lucky! Great job, it really does look like it's from a kit I would buy from a store... probably fits together better too!
    Thanks the project took a few days to do, And the laser took me yrs to save up for.( and still paying for it)
    Neat! Got a copy. I was thinking however that I might make a variation on this that I could show at the local SF&RPG convention. Cosine.
    hows it going , i do have a copy in the instuctions in corel draw also in a EPS file if you over looked them there on the frist page if that helps .if you do have problems let me know try to help best i can . Do you mind tell me what the SF&RPG convention
    thanks
    Hack
    http://www.firstfridayfandom.org/cosine/
    January 21-23
    details at the link in the first line
    Cosine 2011 in Colorado Springs.
    You may have covered this in the text but I was wondering where I could have some wood like this cut to make some FIFO Food shelves and how much it would cost. A FIFO storage (See Attched Pic) is a container for storing can goods where the oldest cans are used first and the newest cans are placed on top and roll to the back and are used later. I want to build about 15 to 20 of these.
