3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Word Clock - Arduino version
Step 3The hardware - Populate the controller board
  • last photo ←
Now that we have an etched, sized, drilled and cleaned PCB, we need to start mounting components.
POPULATE THE PARTS IN ORDER OF SIZE
I soldered all of the components, using the stencil layout as a reference.  I started by mounting the six jumpers that I needed to place because I used a single sided board.  Then I soldered the header pins and the IC sockets, Then the resistors, diodes and off board connectors.  Finally, I plugged in the Integrated Circuits and the Arduino Board, and that step was done.
Note there there was a small change with the final board version - the two resistors (R2 and R3) are actually mounted below where the photos show them, and jumpers are installed in the corresponding space.  Just follow the parts layout for the exact placement.
It was a very restful 30 minutes to do the soldering.   Make sure that you use some sort of fume extraction when you solder.  To many fumes can end up being bad for you.
Here are heaps of photos, showing the steps I used to populate the board.
14 comments
Oct 5, 2010. 7:08 AMgirino2n says:
I finish my clock, excelent project. I just have doubt about the wire under arduino, but I found one picture with the correction.
Thanks for the instruction... it is success in my house.
Oct 14, 2010. 11:03 AMgroszek says:
Ha ...no worry ;p
Aug 21, 2010. 2:06 PMbrainchildpro says:
While following your scematic I set up my breadboard to run an array of single leds. I am using a full arduino but I cant seem to get the ULN2003A to work right. The leds will light up if I just attach them to the HCF4094 in the correct order but they just stay on when I attach them to the ULN2003A dimming only slightly. Have you ever run into an issue like this? I am new to the arduino and electronics in general so its probably my fault its not working.
Aug 21, 2010. 8:54 PMbrainchildpro says:
Pin 9 was my culprit. It now works the way it is supposed to. Thank you for your help. I would say your a genius but I think that would understate it :-)
Aug 8, 2010. 10:51 AMArduino678 says:
Do you have any pictures of the back of the board (arduino duemilanove version)?
Aug 10, 2010. 6:19 PMArduino678 says:
I already have the arduino module and don't plan on using it for a while. I am going to make the duemilanove version (I already purchased parts for it). If you have any pictures of the arduino version that would be great if not I will base all of it off of the layout you have given. Thanks!
Feb 7, 2010. 9:47 AMComhippy says:
The big, blue part is an arduino mega, right?
Dec 1, 2009. 3:40 AMlotusandy says:
On step 3 you state "12Mhz Crystal if you are not using a module"
Should this not be 16Mhz?
Andy
Dec 2, 2009. 1:18 AMlotusandy says:
Don't wish to sound like a picky ****** but in the BOM you list 4049, should be 4094.
Andy
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
364
Author:drj113
I have a background in digital electronics, and am very interested in computers. I love things that blink, and am in awe of the physics associated with making blue LEDs.
