3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Word Clock - Arduino version
Step 8Making a simple enclosure
  • last photo ←
I had some spare time before I had to be somewhere else, so I decided that while the saw was out for cutting baffles, I would make a simple enclosure.
Before you do anything, remember the basic workshop safety rules - wear safety goggles, keep fingers clear of rotating saw blades, and generally don't be stupid.
I used chipboard, because (you guessed it) there was some in the garrage.
I trimmed the board to a uniform width for the top, bottom and sides.  Next I cut the bottom and top to length.  Once I was happy with the size of the bottom, I cut a couple of grooves for the display and stencil PCBs to sit in.  Then I measured and cut the sides.  I glues the bottom and sides together and used chipboard screws to hold them together.  Note that I didn't glue the top - you need to be able to remove the top if you want to extract the display or stencil PCBs.
Next, I cut a piece of thin ply as the back.  Then I mounted some back supports into the box soI had something to screw the back into.  Next, I mounted the Controller PCB, being careful to use washers between the back of the board and the wood, so I didn't put stress on the solder connections.
Finally, I routed the cables through holes I had previously cut in the back, mounted the button board on the back of the case, and closed it up.
WHOOT - It works, and looks great.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
364
Author:drj113
I have a background in digital electronics, and am very interested in computers. I love things that blink, and am in awe of the physics associated with making blue LEDs.
