3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Word Clock - Arduino version
Step 9Bill of Materials
Here you will find the complete parts list you need to create the project yourself.
Bill Of Materials
Controller board
Arduino Duemilanove module
ULN2003A Driver IC * 4
4094 Shift Register * 3
5mm red Led * 2
1K Resistor * 4
1N4004 Diode
2 Pin PCB Mount Screw Connector
3 Pin PCB Mount Screw Connector
26 way header
8 way header * 2
6 way Header * 2
16 Pin IC Socket * 7
Controller PCB
Display board
5mm blue LED * 117
360R resistor * 25 (can be 680R - see step 4)
36R resistor * 25 (can be 270R - see step 4)
26 way ribbon cable * 30cm
26 way IDC Connector
150mmx150mm fiberglass / perspex mounting board - or Display PCB
Button board
Red Pushbutton
Black Pushbutton
Veroboard - 3cm x 2 cm
wire (3 strand) - 30cm
Stencil board
150mm x 150mm single sided fiberglass PCB material
150mm x 30mm fiberglass PCB strip horizontal baffle * 10
14mm x 30mm fiberglass PCB strip - vertical baffle * 10
Hot Melt Glue
Power Supply
12V DC, 500mA Wall Wart Plug Pack.
9 comments
Sep 25, 2011. 11:26 AMcvaast says:
Where did you buy your shift registers? I just can't find the right ones, the 4049 are almost everytime inverting buffers.
Jan 10, 2011. 6:27 PMChiefston says:
Does anyone have a place they have found 26 conductor ribbon cable with a 2.54mm spacing? It seems impossible to find online! Is it possible to combine multiple ribbon cables into a larger one (as in using two 13 conductor ribbon cables side by side in a 26 conductor IDC)? Also, could I buy a ribbon cable with more than 26 conductors and then remove the extra conductors with a hobby knife? Thanks in advance for any assistance
Jan 10, 2011. 8:27 PMChiefston says:
Thank you Doug! I have realized the error of my ways, and am now clear on how ribbon cable and IDCs connect. I was trying to use .050 ribbon cable with a .050 IDC, and I also bought .050 unshrouded header, which is WAYYYY too small for newbie soldering.
Your quick reply is much appreciated!
Jan 2, 2011. 5:46 PMSchmidty850 says:
Can you enlighten me on where you got your 360R resistor and 36R resistor?
Jun 28, 2010. 11:27 PMT.Rockwell says:
WOW. nice instructable!! i know nothing about electronics, and really entertain a strong likelihood that due to your detailed and thorough instructions, i could build this!!! this is still one of the coolest things i have seen in instructables! one quick question if i may.... What do you estimate the total cost of all of the components to be? just some rough idea.... thanks again for a great one........ i think id like to combine your ideas into a steampunk version.....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
365
Author:drj113
I have a background in digital electronics, and am very interested in computers. I love things that blink, and am in awe of the physics associated with making blue LEDs.
