Introduction: The X288 SERPENT
My grenade launcher. Launches the X4.
Step 1: The Top of the Barrel
The top part of the Barrel.
Step 2: The Bottom of the Barrel
The bottom part of the Barrel
Step 3: The Ram
The big ram.
Step 4: The Side Plates
Make two of each, and attach to both sides as shown.
Step 5: The Pseudo-Magazine/Club
This a false Magazine that is best used as a club.
Step 6: The Small Frontal Bit
A tiny piece.
Step 7: The Demented Frontal Shell
The front part.
Step 8: The Handle
The part to which one holds on.
Step 9: The Front Side Plates
These will connect steps 7 and 8.
Step 10: The Bottom Brick
This piece sits at the bottom.
Step 11: The Hinge-y Trigger
These hinge-y parts will become the trigger.
Step 12: The Top Brick
The top part.
Step 13: The Other Plates
Plates that protect the trigger.
Step 14: The Back Brick
This part sits at the back
Step 15: The Pull-Down-Er
This activates the weapon.
Step 16: The Stock
Your shoulder rests here.
Step 17: The Handle and Connection
Your hand rests there. Also, connect.
Step 18: How to Use
To Load, Pull back the Giant Ram and pull up. It should snap into place, If not, try again. Also, don't overload on rubber bands... If you do, the grenade will explode upon firing.
Step 19: Regular Fire Adapter
If you want to fire regular rods, make this and place it in picture 2 when needed. When not needed, place in picture 3.
And then... you are done.
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    whats in between the 2 yellow connectors at the top of step 15?
    plz reply
    wouldn't the grenade be better with blue spacers?Even if it makes it harder to find the pieces you would get better results surely?
     If you want the rating of this gun to go up, and potentially even over 4 stars, all you have to do is make the second picture on the intro the main first picture :)
    also 5 stars
    I have a feeling he doesn't really care about ratings. He's running with the ball machine crew on ibles.
    ball machine crew?!
    should make the bottom hlaf an actua rod firing gun with mag and sorta looks lyk a longer weirder p90-but has lots of potentiol
    cool, it works as a shotgun if you over band it!
    i have build an other knex granadelauncher myselfs. it is powerfull, and has an true trigger. + it can hold lots of ruberbands without breaking the rod. should i post mine?
    sounds nice. post it, please.
    look at the date, i have recyceled my grenadelauncher almost 5 months ago.
