The attack of the ROBOTIC MUTANT ALIEN!!!!!
 by M.C. Langer
FeaturedContest Winner
Officially, I'm the first Colombian testing Sugru. It's a privilege and a good excuse for making something I always wanted: an evil mutant thing with robotic legs. Arachnid robotic legs. I love Krang from the "Teenage Mutant Ninja Turtles" and the Arachnotrons from "Doom II", and I dream with green viscous aliens riding robotic spiders, shooting plasma balls and trying to rule the world.
http://www.youtube.com/watch?v=wpXaRt9wXO0
So, lets build one!!! We will hack a damaged toy car, assemble some junk pieces and add green silicone rubber, courtesy of Instructables and Sugru!
http://www.youtube.com/watch?v=UUGsdkp2N-o
Step 1: Testing SUGRU.
What is the first step when you have a new toy? Well, to test it.
I had to know if SUGRU was that good, if it was a good choice for the project, how much SUGRU I could find in a sachet and how many sachets I could use. And find out if I am allergic to SUGRU (luckily, I'm not).
In the contest I found a great instructable that gave me some lights:
http://www.instructables.com/id/Sugru-Basics-and-Tips/
But, nothing like the empirical experience. So, in a non-related experiment, I repaired the broken band of my favorite watch. I used one black sachet. The superglue was only for keep togheter the pieces while Sugru cures (Before this experiment, I tried to repair the watchband with superglue only, and it was a bad idea).
The result? SUGRU IS AWESOME! And I think it's enviromental friendly because, if you make a good work, you don't have to thrown away your damaged plastic stuff. Just fix it and it will last for some more years. I made this experiment two weeks ago, and the watchband don't show rupture signs.
I has one suggestion: it will be good more Sugru colours. Yellow, pink and red would be great.
Well, let's go to the main project.
Step 2: Recipe for World Domination!!!!
MATERIALS:
1 electric toy car (you will need one who rolls straight forward)
2 3D glasses (we will need the glasses 4 legs)
1 AC adapter plastic box
6 iron angles
1 long plastic bar (I used one from a printer. You will need to cut it in two equal bars)
1 rectangular plastic piece
1 Big LED
1 Switch
1 AA 2 batteries holder
1 conic plastic piece
3 green Sugru sachets
cupper wire
1 deodorant cap
1 facial cream cap
2 vents
red and black wire
screws and bolts
Tin soldering
Superglue
TOOLS
Dremel Rotary Tool
tweezers
screwdivers
scalpel
pliers
Wire cutters
Screwdriver kit
Soldering Iron
And don't forget the classic building rules:
1. If you don't have it, replace it!
2. Use protective equipment (dust mask and goggles)
3. Beware of drilled and soldered hot surfaces
4. Work in a good ventilated area.
5. Always have junk in stock
6. Enjoy!
Step 3: Hacking the toy car
You will need a simple electric toy car, with the simple action of going forward. The idea is to extract the gearbox (with the motor incorporated) and fit it into the AC adaptator box. I could use the toy's body, but it's made of very cheap plastic, and could get broken in the first fall.
Because of the fragile plastic cover of the gearbox, using screws to attach it to the adapter box wasn't the best idea. So, I have two options: superglue o black Sugru. Both are good enough, but each one has its advantages and disadvantages:
  • Superglue: it's instantaneus and strong enough. On the other hand, it leaves white dust, it's eye-irritating and if you are a beginner, you could leave scraps of cyanoacrylate in the project or worst, stick permanently the gears.
  • Sugru: when it cures is great, but you have to wait 24 hours before continuing with the project. And is a little bit bulky.
The choice is yours!!!!
Step 4: Crank mechanism
You love walking robots but you don't have advanced knowledge in robotics? Then you will love this simple mechanism.
But remember something important: one wheel must have its angle directed to the front. The other wheel must have its angle directed to the back. This configuration allow the alternate movement. This is a video of how works the crank mechanism:
http://www.youtube.com/watch?v=z8Im-ylarms
If you do it wrong (both angles directed to the same side), the result will be a little bit... disturbing.
http://www.youtube.com/watch?v=5GlFnG3yhnQ
Step 5: The legs
You can use the four legs from the 3D glasses. Fix them to the angles, and when you have ready the electromechanic mechanism, cut its ends looking for the best performance.
Step 6: Electronics and closing the body
Relax! If you saw  the mechanics are simple, the electronics are even simpler. Just another parallel circuit with one led, one motor, one switch and the AA battery box. When you finish it, attach the facial cream plastic cap to the adaptator cover, and stick it to the spider body.
Step 7: The Invader!!!!!!!
Now is time for our little green monster. It's simple: just cover a plastic cap with enough Sugru and form it.
Well... WHAT ARE YOU WAITING TO INVADE THE WORLD??? :-)
Step 8: The thing with the Sugru grip in the legs...
I have a lot of comments about why I don't use Sugru in the legs tips for better grip. Well, when I was making the monster, I did the experiment with rubber from tires (you know, I have only a Sugru pack, so I needed to experiment with a cheaper substitute), but it didn't work, so I left my Mutant Sugru with its bare feet.
But you will never forgive me if I don't show proofs. So I put some Sugru on the legs, with two variants: Sugru in the four legs and Sugru only in the front legs (sillyzombie666's idea).
Four legs with Sugru
The video explains itself.
Why it's not working? Sugru can be an excelent rubber grip for walking robots, but not for this, because the front leg and the back leg are practically the same piece. If you look carefully the Intro videos, part of the normal movement includes a little slip when the front leg downs (and the back leg ups). With the rubber grips, we don't have the slip, and blocks the legs.
Front legs with Sugru
It's a little difficult to start, but has a better grip when gathers momentum.
1-40 of 60Next »
RENATO.ROSS says: Nov 2, 2011. 4:02 PM
OLÁ MEU AMIGO COLOMBIANO, ESPERO QUE ENTENDA PORTUGUÊS...
VI TODOS OS SEUS INSTRUCTABLES E ACHEI O MÁXIMO, MEUS FILHOS TAMBÉM ADORARAM! SUA CRIATIVIDADE É MAGNÍFICA! GUARDO AQUI NA MINHA CASA UM MONTE DE SUCATA ELETRÔNICA MAS NUNCA SOUBE COMO UTILIZÀ-LA, AGORA VOU USAR TUDO, COPIANDO UM POUCO SEUS MODELOS. POR FAVOR, ME TIRE UMA DÚVIDA: QUE MATERIAL UTILIZA PARA FAZER AS PERNAS SERRILHADAS DOS SEUS ROBÔS??
M.C. Langer (author) in reply to RENATO.ROSSNov 2, 2011. 7:23 PM
Hi Renato! Thank you very much!! Well, for the robot legs I use iron pieces used for hang frames. Y si entiendes español , uso las piezas metálicas que se atornillan detrás de los cuadros para colgarlos en la pared. Saludos, amigo brasilero!!! :-)
The nerdling says: Jun 23, 2011. 5:41 PM
hello your robots are really cool
hello, this was just a test to see if html tage work on instructables
M.C. Langer (author) in reply to The nerdlingJun 23, 2011. 8:16 PM
Thanks!
Planemaster101 says: May 22, 2011. 2:47 PM
You probably should have made him walk on like dirt or natural ground, maybe even sod, for the video, cause I noticed him sliding as his legs attempted to make it across the smooth surface. Maybe make another video with him doing that, it seems built for that kind of traction. Still a 5/5, though! I would try and build it if I had the proper materials. =)
goldhawk348 says: Mar 19, 2011. 6:57 PM
whats the rings for
eee444 says: Nov 18, 2010. 3:26 AM
wow,is this true?
M.C. Langer (author) in reply to eee444Nov 18, 2010. 6:36 PM
Yeah!!!! ;-)
TSC says: Oct 22, 2010. 2:07 PM
Sweet!!!!!!!!!!!!!!!!
M.C. Langer (author) in reply to TSCOct 22, 2010. 8:51 PM
Thanks!!!
TSC in reply to M.C. LangerOct 23, 2010. 11:34 AM
Your welcome!
xZATANx says: Oct 14, 2010. 7:56 AM
Simplemente Impresionante !!!
Saludos de otro Colombiano !!!
M.C. Langer (author) in reply to xZATANxOct 14, 2010. 6:44 PM
Muchas gracias Zatan! De qué ciudad eres?
xZATANx in reply to M.C. LangerOct 15, 2010. 9:18 AM
De la CIudad Bonita: Bukara !!!
Por cierto yo tambien tengo varias cosas como motores de carritos, cables, engranajes y demas cosas q no he querido botar a ver si algun dia me animo y hago algo, el problema es q mi mujer me pide q bote esa "basura" jeje.
Salu2
lemon rind in reply to xZATANxOct 19, 2010. 1:29 AM
YOU CRAZY COLUMBIANS!!! Na just kidding this is meanest!
M.C. Langer (author) in reply to lemon rindOct 19, 2010. 7:25 PM
LOL!
And we are "colombians"! :-)
isaaclo says: Oct 16, 2010. 5:44 PM
wow... that thing looks pretty cool wonder who left it there
M.C. Langer (author) in reply to isaacloOct 16, 2010. 7:50 PM
Someone who thinks that MacGyver is just impossible fiction... LOL!
Halestorm says: Oct 16, 2010. 11:01 AM
I don't think I'll be able to find a motor gearbox quite like the one you have, so would using a RC Car gearbox work the same? Also I don't suppose a project box could be used instead of a AC Adapter Box?
Btw, this is a awesome idea in its own simplicity. :D
M.C. Langer (author) in reply to HalestormOct 16, 2010. 5:22 PM
Thanks Halestrom! Well, this is a concept, so you can be flexible. If you find another kind of gearbox, awesome! But you will need a force gearbox, not a speed gearbox. If you try adapting an electric screwdriver, it will be slower but stronger!
isaaclo says: Oct 15, 2010. 4:41 PM
where do you get the plastic cone from
M.C. Langer (author) in reply to isaacloOct 15, 2010. 7:12 PM
I found it dumped on the street.
el santo says: Oct 12, 2010. 2:21 AM
Ya tienes mi voto, compañero! :)
Hace tiempo construí un bicho parecido utilizando también un juguete roto. Le puse unas patas hechas de alambre y tenía el mismo problema de tracción al funcionar que el tuyo. Con unas bolitas de goma como pies conseguía más agarre al suelo y no patinaba pero casi no podía moverse. Sin las gomas caminaba rápido pero patinando.
El problema creo que está en la poca fuerza del motor y en el hecho de que camine arrastrando todo su peso sobre las patas en lugar de elevarlas consecutivamente.
La solución: cambié las patas traseras por ruedas.
¡Espero que ganes!
M.C. Langer (author) in reply to el santoOct 12, 2010. 8:05 PM
Santo!!! Amigo!!! tiempo sin saber de tí!!! Gracias por tu voto.
Oye, ¿sabes cómo sería chévere aplicar tu idea de "patas adelante, ruedas atrás"? ¿Recuerdas la película de Doom, en la que el demonio "Pinky" se creó a partir de un tipo en silla de ruedas que se convirtió en mutante??
http://www.niubie.com/2008/01/el-baul-de-los-recuerdos-doom-ii-parte/
la parte de atrás de hace con ruedas, y la de adelante con el cuerpo cubierto de latex... sería genial!!!
el santo in reply to M.C. LangerOct 14, 2010. 2:07 AM
Hey Mario,
Si que me acuerdo del demonio 'Pinky' de la película de Doom ¡que buena idea! :D
Muchas gracias compañero!!
y suerte!!!
M.C. Langer (author) in reply to el santoOct 14, 2010. 7:44 PM
Muchas gracias amigo!!!!!!! :-)
ppsailor says: Oct 14, 2010. 5:24 PM
Hola Mario !
Ingenioso, bonito y bien explicado para su construcción.
ppsailor
M.C. Langer (author) in reply to ppsailorOct 14, 2010. 6:20 PM
Muchas gracias ppsailor!!! De dónde eres?
LordCrowen says: Oct 13, 2010. 7:57 PM
Oh cielos, no se quien sera el autor, pero esta genial Jajajajaja, un voto mas mario.
M.C. Langer (author) in reply to LordCrowenOct 13, 2010. 7:58 PM
Jajajajajajajaja!! Don Juan, siempre es un gusto verlo por estos lados!!! :-)
Aliena says: Oct 13, 2010. 6:10 PM
Marito presidente!!!!!!!!!!!!!!!!!!
M.C. Langer (author) in reply to AlienaOct 13, 2010. 6:33 PM
Estoy buscando Primera Dama. Te le apuntas?? ;-)
kyle brinkerhoff says: Oct 12, 2010. 10:38 AM
your green little guy on their looks like he gets sick from riding that!
M.C. Langer (author) in reply to kyle brinkerhoffOct 12, 2010. 7:37 PM
YEAH!!!! :-)
sillyzombie666 says: Oct 10, 2010. 10:33 AM
you should have used some sugru on the front feet and it would have walked allot better
M.C. Langer (author) in reply to sillyzombie666Oct 10, 2010. 4:54 PM
Hi Sillyzombie666!! Thanks for the idea. Look the last step:
http://www.instructables.com/id/The-attack-of-the-ALIEN-MUTANT-ROBOT-SUGRU/step8/The-thing-with-the-Sugru-grip-in-the-legs/
If you like my instructable, please vote for me. Thanks!
sillyzombie666 in reply to M.C. LangerOct 10, 2010. 9:11 PM
o wow that was very unexpected i thought for sure the front leg idea would work
M.C. Langer (author) in reply to sillyzombie666Oct 11, 2010. 7:08 PM
Well... more or less. But we have our Mythbusters moment! :-)
I think it's "pausible".
sillyzombie666 in reply to M.C. LangerOct 11, 2010. 8:10 PM
i think its mostly the motor strength
M.C. Langer (author) in reply to sillyzombie666Oct 11, 2010. 8:15 PM
Well, it's a walking toy made of a "Made In China" damaged car gearbox. It's a good thing it moves! ;-)
1-40 of 60Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
