The Best Pen Bow in the World and the Most Simple
Published
Introduction: The Best Pen Bow in the World and the Most Simple
in this inscrutable I will show you how to make a very simple pen bow!
Step 1: Step 1
so first what you want to do is take off the cap and put the tip of the pen in your mouth and pull on the end and it should slide out easy
(spoilers alert that is your ammo!) so once you  have done this you are ready to move to the next step!
Step 2: Step 2
all right so you have taken out the pen tube that holds the ink. Now you want to take pliers and pull out the top(in this case in my photo
it is to the right you will see if you don't understand.)after you have done that you will want to take a knife and cut off the back(to left of photo).Now you are ready for the next step!
Step 3: Step 3
all right now you are ready for drilling(optional will make next step easier) make as center as possible for better results.
Step 4: Step 4
(did i mention you need a rubber band?) so for this step you will want to widen out a hole with a knife(or scissors!) to fit that top piece then you want two groves at the ends now you can put the rubber band on and fire that is obvious but pleas do not shot anyone or anything this can hurt very bad now to the next step!
Step 5: Add Colors!!!!!!!!!!!!!!!!!!!!
add any color you want!!!!!!!!!!!!!!!!!!!!!!!!
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Backpack Challenge
      Backpack Challenge
