The clothespin hack, how to scan photographic film without slide carrier. by ilpleut
Step 1: First idea
the easiest way would be to directly put your negative on the window's scanner
but strange pattern like that could appears ...
http://static2.instructables.com/pub/FA3/2RCK/FA32RCK8DVEY6DCNDW.small.jpg
newton ring ...
you negative mustn't touch the window's scanner...
it would be ok for 35mm negative if you put them upside down
not perfect but it's enough for most case.
but this don't work for 120 negative, they don't stay flat ...
bobl13 says: Mar 4, 2010. 5:08 PM
Hope this works ..Trying to do negatives from ww2 ..That dad sent home...I can't find a cheap Negative scanner ..so it would be great if this does the trick.
harolzoidium says: Nov 19, 2009. 5:21 AM
 I'm like heaps late... but does this work with cross-developed slide film?
mzungu says: Mar 23, 2007. 2:18 PM
Does this method needa back light? Your Flatbed scanner looked like it has a back light, most don't.
ilpleut (author) says: Mar 25, 2007. 5:41 PM
Yes, you need a back light. With negative you always need one. but it's also possible to make a back light with translucent glass and a uniform illumination. (and lots of test)
mzungu says: Mar 29, 2007. 10:04 PM
Thanks, that make more sense, I thought this circuvent the back light needed. Duhhh... not a smart one I am. I'll just have to build a back-light now.
hamtons says: Oct 21, 2008. 9:51 AM
I know this is 1 year PLUS late, but it is possible to scan without a backlight. Just do it in the noon with an open window. The sun can provide the light ;) I tried it, it works. In fact the scanner was at the centre of the room when I discovered this. Hope it helps
al_ameer_marco says: Jun 13, 2008. 12:28 AM
hi, just like to ask, is that a canon t90 on the table on your picture?
ilpleut (author) says: Jun 13, 2008. 2:02 AM
yes :) a really good camera, I sometimes using it as a lightmeter when I take photo with old camera (a TLR here)
hitokiri_808 says: Feb 15, 2007. 11:24 PM
Thats pretty cool. I haven't had much luck scanning film... Probably because I was sandwiching it on the bed. What camera do you use for your 120 film? Looks like a pinhole from your scans but I can't tell.
ilpleut (author) says: Feb 16, 2007. 4:48 AM
this photo was taken with a yashica MAT, an old TLR. for pinhole camera, i didn't try yet with 120 negatives, hope to do it soon :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
