3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The complete guide to using LEDs
LEDs con be confusing sometimes so I decided to make a guide on using them. If you have any Questions about LEDs that werent answered in this instructable, Please feel free to comment or question.
Step 1Power intake
power intake
LEDs are wiered about there power intake. Most LEDs require about 3 volts any more, and they burn out and smell bad. any less, and they dont light up good. I know what you are thinking you can use a 1.5v battery such as a AA or AAA if you have a Joule Theif, but that is another instructable. As of amperage, LEDs very greatly across a wide spectrum of highs and lows, but 20mA is standard.
15 comments
Dec 3, 2011. 6:30 AMsaurabh_1603 says:
can u tell how to light led using AC.
Do i have to use diode.
i used 100k resistance for a 230v AC supply, red led worked properly but white led stopped working after 5 seconds and was damaged.Can u tell me why.PLZ
Mar 24, 2011. 9:46 PMjpgomez says:
your explanations are really easy to follow thanks. i have no electrical background, voltage im guessing is the power of something what is amperage?
Dec 24, 2010. 12:04 PMkarlpinturr says:
Right..., so, taking your "R=V/A" to the circular chart, the resistance can be found by dividing I (volts) by E (amps), dividing P (watts) by the square of I (amps), OR dividing the square of E (volts) by P (watts)..?
And the same principal (ie, the central value can be found by ANY of the 3 methods shown) applies to the other segments?
So, if I know the voltage (E) of my power supply and the amps (I) of my LED/LED's, I divide the first by the second to find the necessary resistance..? And I assume that if there's no exact match available, I'd be best using the nearest HIGHER resistance?
But, just a minute. LED's are measured in MILLIamps - does that mean I have to divide/multiply the result of my calculations by 1,000? And how would I know which?
Jul 17, 2010. 2:34 PMrickharris says:
As an aside your using the wrong symbol for an LED.
Jul 17, 2010. 2:32 PMrickharris says:
Not at all resistors cost pennies - You should still nclude a resistor no matter what the power source to allow for changing battery voltages.
Jul 17, 2010. 1:09 AMrickharris says:
There isn't any reason not to use the 9 volt battery as long as a suitable resistor is put in series with the LED to limit the current drawn.
Jul 17, 2010. 2:22 PMRorymi6 says:
You are also at a disadvantage with the mAh of the button cell which can be rather small compared to a PP3 or a AA cell. A single LED on a 9v supply would generally require around a 300 ohm resistor which costs me around half a penny per resistor for a 270 Carbon film 1/4W resistor. This page really needs to explain about resistors and their usage aswell. Rory
Jul 16, 2010. 6:53 PMrimar2000 says:
Well, because this is the introduction to the prologue of the first chapter of the first delivery, not bad! We'll see how it continues...
Jul 16, 2010. 1:41 PMlemonie says:
This needs work doing on it (e.g. spelling), and some more information that gets you towards "complete".
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:techturtle2
I make a lot of things and add my own twists to everyday objects. I would rather make something on my own than buy it. ofton times I save money that way!
