loading
Step 13: Nothing gets this stain out!
Now, it is time to stain your table (just don't stain your clothes)!
In order to stain your table, you will need a sponge brush, stain, Polyurethane, and something to wipe away the stain with (an old t-shirt works great for this). To stain the table, apply one layer to one side at a time, wiping the excess stain away. The longer you leave the stain on before you wipe it off, the deeper the colour will stain.
After the stain has dried, coat the whole table in several (3-4) coats of the Polyurethane to give the table extra protection and water resistance allowing each coat to dry before applying the next coat.
If you desire the bottom of the table to be a different colour than the colour of your foam board, spray paint to your desired colour. When you do this, make sure you seal off the rest of the table with newspaper and painters tape so you don't mess up the awesome stain you just let finish dry!
Because its plexiglass does that mean I can kick it over and use it as a shield?
Yes that is exactly what you should use it for
<p>I've seen the table and now I've gotten to see the instructable. Nice job, now I'm going to do my best to outdo you.</p>
This animated light up table is very similar, but also battery powered: <a href="http://youtu.be/P1o5ji-guiY" rel="nofollow">http://youtu.be/P1o5ji-guiY</a>
This structable Sucks! Way to not go into the most important part... lights!
Cool
Would the lights still work with a plug-in type dimmer, such as this: <a href="http://www.homedepot.com/Electrical-Dimmers-Switches-Dimmers/h_d1/N-5yc1vZbnniZ1z11a2c/R-202051141/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053">http://www.homedepot.com/Electrical-Dimmers-Switches-Dimmers/h_d1/N-5yc1vZbnniZ1z11a2c/R-202051141/h_d2/ProductDisplay?langId=-1&amp;storeId=10051&amp;catalogId=10053</a>?&nbsp; Or would I need an in-line one such as this: <a href="http://www.homedepot.com/Electrical-Dimmers-Switches-Dimmers/h_d1/N-5yc1vZbnniZ1z11a2c/R-100671794/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053">http://www.homedepot.com/Electrical-Dimmers-Switches-Dimmers/h_d1/N-5yc1vZbnniZ1z11a2c/R-100671794/h_d2/ProductDisplay?langId=-1&amp;storeId=10051&amp;catalogId=10053</a>?&nbsp; Thanks!<br> &nbsp;<br>
Just picked up a frosted glass top table at garage sale (yard sale,if your an American) for $5, start project tomorrow. <br>Where can I get the foam for mounting the leds into (Sydney,Australia) or can anyone suggest an alternative ? <br>Would heat be an issue ? <br>Great instructable,easy to follow, Im inspired !
Just a question about the lights from Deal Extreme. If you switch them to one mode and them unplug them from the wall and them plug them back in later will they be in the same mode? Or just stay off until you hit the button again. I want to order a similar set from DX. but only if they will work when connected to a timer.
Excellent instructable! I love that it's something I could make without Josh's help.
uhulll<br>you won!
GENIUS!
i want to build something like this years ago, and i have forgotten about it untill now, but i was wondering sinde i doubt that i can find those diffuser sheets can i put white plexiglas instead of diffuser sheets and clear plexi??
You can buy 'opal' plexiglas / perspex, then you would not need a separate diffuser sheet.
yellowcatt is right, you could use opal Plexiglas instead of the diffuser sheets, you would get soft edges on your LED boxes. I personally like the boxes to have a hard edge, and that is what the thin diffuser sheets allow you to do. If you use the opal Plexiglas, each box will have edges that fade out creating more of a blend between boxes instead of the sharp lines.<br>
thanks for the replays guys, i will try to find that opal plexiglass....
The opal plexiglas/perspex is available in different grades offering various degrees of diffusion, it should not be too much problem to track down, it is used by sign makers in some illuminated signs. Another idea would be to use 'frosted' plexiglas/perspex.
This is totally mind-blowing and it will be even more so when I challenge my nemesis to a game of chess on a table like thissss, mwah-ha-ha!! 8x8 though, with a null border. What a brilliant idea!
Love it already looking forward to build a coffe or couch table with your idea for the lights. this is really awsome and i like your instructions i hope im gone be able to put something like this together in here. <br> <br>Awsome idea thanks Andy!
Oh snap, simplicity at its best. Awesome
nice nice niiiiceeeeee<br>
The whole circuit is at mains potential, I don't really like the idea of using the button off the circuit board exposed like that, since you are directly touching the switch, unlike the design in the case.<br><br>A mains rated push button would be a good idea, some older ATX computer cases had them to replace the old style latching ones, big clunky power switches.<br><br>Other than that, nice instructable. Like the final result.<br><br>Did you try 2 leds in some squares to get some colour mixing happening?
I can see where you are coming at from a safety standpoint, but the switch should only be at +5V max not the 120Vac. The push-button is there to bridge two contacts on the IC to signal the change in the pattern. The main I/O switch is a mains rated toggle switch though.<br> <br> As far as the colour mixing is concerned, I did not try it. It should produce a nice effect. The only problem is not being able to directly control each LED colour with the setup I have now.
Okay that's freaky. I did a similar thing with a tic-tac-toe format with the exact same parts from the exact same stores. Small world.<br><br>BTW. You're project looks great.
Thanks!<br> DX is an awesome store (as well as the others). If you wouldn't mind, I would like to see some pics of your table. It seems like a cool spin on a normal table.
Sure. I used the 30 battery operated lights and then chopped the extra leds off. It's not a table. it's more of a stare at it for 5 minutes. A table seems much more practical. I'll post a pic asap.
i LOVE THIS i have been searching the site for 4 months now for something like this which required little to no electrical skill! im gonna work on mine next summer when i have time!
Really cool idea, I am not the greatest with microprocesors, or anyother complicated piece of technology for that matter, and this seems like a great and simple idea.
You do not show a picture of the lights
Yeah....&nbsp; Sorry about that. Either I didn't take a picture of them before I glued them in, or I just can't find them, but there are several pictures of the lights at the website I bought lights from <a href="http://www.dealextreme.com/photogallery.dx/sku.16212~seQ.5">http://www.dealextreme.com/photogallery.dx/sku.16212~seQ.5</a> . Let me know if you have any more questions about them.<br>
It looks very nice. I would totally love this in my dining room :)
Thanks!<br> <br> You should try making one (and I think it would be used a lot judging from your Instructables)!<br>
I like the fact that he/you took Christmas lights and did this. Totally there with you on the lazy / impatient thing.
Yeah, using the lights made the project a lot easier, plus they included animations!
awesome
I like it
man you confuse me with the biscuit! did you ate it after all?....clever idea to use it to absorb the liquids.....I liked the project... very simple in electronics and little complicated in construction, but I will try it for my coffee table...5/5
Haha, no I did not eat the biscuits... I would have gotten a lot of fiber though... They work by swelling when they come into contact with water based glue thus &quot;locking&quot; the two pieces of wood together along with the glue bonding them together.<br> <br> Hope your coffee table build works well!
Cool.
About This Instructable
64,145views
413favorites
License:
More by mosesman08:The easy light up, animated table. No electronics skills needed!
Add instructable to:
