3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The flower lamp
The flower lamp
An easy and fast project.
In a special shop for light bulbs I found a beautiful glow lamp. Inside is a flower and if you provide mains it lights up in red with green leaves. For this bulb I needed a stand with a connector to the wall outlet and a switch. And YES Steam Punk stile was a must. :-)
I build two different types dark wood and light wood with brass applications.
Step 1The switch and cabling
I found a black switch with a 4mm leaver. I attached a brass ball nut to the leaver.
Than I started the cabling of the mains line.
The mains lines is connected to the lower pair of contacts of the switch (blue and brown)
The cables to the bulb socket are connected to upper pair of contacts.
I soldered the cables to the contacts.
For more safety I insulated the wires by a shrink hose.
Please don´t forget to connect the EARTH (yellow / green) wire to the bulb socket!
4 comments
Oct 1, 2011. 9:36 AMjblackwell3 says:
Would a good way to do this be to use the plug from another lamp? So, rather than wiring it direct into the mains, you just use a plug socket. You could make it portable then. Unless you have and I missed it :s (which is entirely possible haha)
Aug 12, 2011. 6:16 AMuhclem says:
Nice instructable and bulb. I have found these bulbs used as-is tend to darken themselves quickly by sputtering the electrodes onto the inside of the glass. This can be reduced with a current-limiting resistor.Try 100K 1/4 watt in series with the bulb. It will not be as bright but it will last a lot longer.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
89
Author:Horatius.Steam(Steampunk Design)
I am a home constructor, an inventor and a dreamer. If you ask me who guided me and who inspired me then this people comes in mind: Carl Benz, Guglielmo Marconi, James Watt, Thomas Alva Edison, Nicola...
more »
