The "i have no clue what geocaching is", geocaching guide!
 by sheich
Contest Winner
Little do most hikers know but geocaching has always been right under their noses; It's an international hobby inspired by adventurist spirits that just love the woods.... or wannabe land-pirates that don't mind sharing.
So what is it exactly?
Geocaching is an entertaining adventure game for gps users. The concept is individuals set up 'caches' all over the world and share their coordinates online so others can find the hidden cache. If you do take a reward from the cache you must leave something else within the cache.
So how easy is it?
Each cache has a different difficulty considering the terrain, distance and how well hidden it is. Most caches are family friendly but some will definitely, 'bring out the sweat!'
Step 1: So how do i start?
Expensive gear is not recommended! More importantly, I suggest cheap, easy to use equipment that does its job and thats it.
I've been using a etrax legend by garmin and highly suggest it, but consider your options and heres a mini guide about gps recomendations taken from http://www.geocaching.com/about/buying.aspx
Feature considerations for good geocaching GPS gear:
Basemap. This is highly recommended. The additional cost is marginal, and the increase in the equipment's usefulness is substantial.
Channels. Use a receiver with 12 parallel channels. This should include most manufactured after 1997. Older, single-channel receivers are much slower and may not be as accurate.
External antenna jack. This allows the equipment to be mounted inside a vehicle. It is not always possible to obtain good satellite coverage through a front windshield. Even backpackers will benefit from the ability to safely store the receiver inside a pack with an antenna attached to backpack shoulder straps.
Interface. If using the receiver with a computer, be sure that it includes both data in/out ports, and make sure it's NMEA compatible.
Memory. This is used to load detailed topographic or street-level digital maps into the receiver. Topo maps use up a great deal of memory. Capacity should be at least 8 megabytes, or the receiver should include the ability to accept a memory card for as much memory as needed.
Power source. Use a cigarette lighter power cable whenever possible. If you're only using batteries, make sure to carry spares and use a solar charger for extended field use.
Rocker keypad. Using a receiver without a rocker keypad is like using a computer without a mouse.
Screen size. For visual ease of operation, use a receiver with the largest screen that can be realistically carried. Screen size is measured diagonally. Color is great and helps define map features, although it does burn battery power.
Waterproof. Sooner or later the gear will get submerged. Get gear that is at least water-resistant. Plastic bags and boxes give electronics a little additional protection.
Step 2: Using the GPS
Heres the steps and some pictures to mapping a cache's location using Gamin's Etrax legend.
Create an account on http://www.geocaching.com/ to access location waypoints in your zip.
Once you have coordinates to a possible cache, power on your GPS and go to 'main menu'
On the 'main menu', go to 'mark' and that should bring up a new screen
Enter the location coordinates into the 'location' block as they appeared on the internet, (ex. N 42* 12.345, W 072* 12.345)
Some GPS's might have other options such as elevation, distance, or bearing, well don't bother with those, your only going to need to input the location coordinates.
At the bottom of the 'mark' screen should be either 'map', 'goto' or 'ok'.
'Ok' saves the location for later, 'Goto" pulls up a compass with an arrow and distance pointing towards the cache, "Map' (which i use) creates a map of your current location and a path to the cache.
Some other tips,
I suggest reading the entire description of the cache before going out, usually the owner of the cache will have information to help you find it, or warnings such as poison ivy or bee's nests around the area. Also look to see if the owner suggests a parking lot, it helps a lot to know where to park.
Step 3: Additional Tips and Hiking Gear
Heres some tips I've found useful....
Always go hiking and caching with a buddy, that way if you fall off a cliff someone can have a good bar story for later.
Many caches are off trail so be aware of your surrounds, Bug-spray rarely stops a bears from clawing your buddy's face.
Bring water bottles and DON'T DRINK FROM STREAMS, animal's poop in those.
Inevitable your GPS will lose signal every now and then from overhead tree's and rock's but eventually it should clear up and most caches are located in clear sky locations.
The Final 30 feet is the hardest, most likely your GPS will bounce, so put the gps down and start circling the area looking for good hiding spots, and WATCH FOR WHAT YOU POKE, don't go sticking your head in a hole if it doesn't look safe.
OK, so you found the cache right now what?
Usually if you have kids they like to exchange Macdonald's toys with the other ones other kids left behind,
For the rest of us that aren't amused with an Indiana Jone's windup, usually adults leave behind geocoins, which can be tracked online and then placed within another cache.
I can't stress this enough though, If you take something PLEASE leave something!
Also, if you'd like to leave comments to the cache owner they usually appreciate that and it's nice to know the condition of a cache and what people have been leaving in it.
1-40 of 65Next »
bajablue says: Sep 28, 2012. 6:19 PM
Great Ible... and I'm no longer clueless! ;-)
xanxer82 says: May 21, 2012. 7:53 AM
Nice 'Ible. I've been Geocaching for a while. Geocaching.com is a cool site and makes it easy to load coordinates to your GPS or GPS enabled smartphone.
On a side note, if you run out of water you can drink from a stream but boil, filter and/or treat the water first. Iodine tablets are cheap, easy to use and weight very little. (Just don't use them if you have thyroid issues. There are water bottles designed to filter water for sale at most places with an outdoor section.
Have fun and happy trails!
artworker says: Feb 9, 2012. 3:40 AM
A bad day of Geocaching is anytime better than a good day at the office.
hbrommer says: Jan 18, 2012. 12:54 AM
hey this is the first i have heard of geocatching & it sounds great, by the way where did you get your geocoin?
glier says: Jun 18, 2011. 10:41 PM
i can bear mosquitoes, enraged bird (their eggs can be a good breakfast) and haven't happened to get close to a bear to shake hands but... (PWAGH GET AWAY THAT INSECT FROM ME), i hate the fealing of light things touching my skin.
thanks for the info, i'll try to apply it in my next hike
Tommi Potx says: May 30, 2011. 8:50 PM
Ooooh, why all this arguing? Who is Fred82664 with the attitude and poor grammar? Why the big peeing contest? It's just Instructables.
Chill dudes!
DELETED_jorgegunn says: Jan 3, 2011. 8:12 PM
I just want to add that an also Highly exciting part is Hiding them. We just made and hid our very first Geo Cache and today it was approved and put up on Geocaching.com. I am so excited to see how everyone likes it, its pitch dark and i'm thinking Boy i wish someone would go find it right now. We actually put up an instructbles on it because its voice activated. You can find it under voice activated geo cache if anyone is intrested. Anyways if you have had lots of fun finding but havent hid one yet try it, i promise it wil make you tingly all over.--Jorge
Fred82664 says: Jul 30, 2008. 9:27 AM
sound cool ! but the gas is about $5.00 or more a Gal. that makes it a bit short on doing all that for a $ . 05 worth of bronze and leaving one behind. this must be a game for the Rich and Oil tycoons
Pie Ninja in reply to Fred82664Apr 20, 2010. 4:51 AM
You know, if you think about how much it costs to do something compared to how much you get out of it, nothing is worth it.
Fred82664 in reply to Pie NinjaApr 20, 2010. 8:08 PM
that sounds like a statement made form someone that has no idea about doing much investing in any thing. You should run for some Government Election you would fit in vary well with the majority of them
Pie Ninja in reply to Fred82664Aug 25, 2008. 7:35 PM
They're all 15 year old Australians who like to burn things?
Fred82664 in reply to Pie NinjaApr 21, 2010. 3:18 PM
I understand now here in the USA it is all about ROI (Return On Investment) If the return dose not exceed the investment then is is a lose.
Tape-structable in reply to Fred82664Apr 21, 2010. 4:55 PM
It's not about the cost you put in and what you receive out of it. Its the experience you have with your friends and family.
The point is to have a good time! Have you ever been hiking before? Surely you drove somewhere thats challenging. Let's say I was planning one, I would look up if there are any caches around that location I'm hiking, because I'm going anyway.
I agree though, gas is expensive these days.
Fred82664 in reply to Tape-structableApr 21, 2010. 7:34 PM
When hiking I do look for things like edible and medicinal plants. I am  a survivalist. Trinkets are nice to look at but don't hold much value to staying alive in the wild lands. But yes I do see your point if I was there and was thinking about such things as a player of that sport it would be cool. I did not see it vary fun let alone useful to spend a lot of gas money out  just to find a $.50 trinket.
integrator in reply to Fred82664Apr 25, 2010. 10:18 PM
I'm extremely new to geocaching, like a day. But there are 20 or 30 caches within 2 or 3 miles of me, and at least several hundred in the area I drive daily.
As far as value, it's not about that. You're supposed to leave something of equal or more value to what you take. It's about the hunt, finding the treasure, solving puzzles. If you don't like any of those things, or the outdoors, it's probably not for you.
Fred82664 in reply to integratorApr 26, 2010. 11:40 AM
Vary good for you and your location Mr Integrator lol you might have me shaking in my boots with your intimidating ID name   ROLFAO ! Even professional that solve puzzles, find treasure and have good hunting look at the high dollar they can make as profit.  I can say the only thing your statement  has truth is wasting my money is not for me. when I could give it to some one that is in need of a vital life sport items ( Example: Medication, Food, Cloths, Shelter) you know those things greatly rich and wasteful people hoard.
blue_note in reply to Fred82664Jun 23, 2010. 2:28 PM
LOL yes his name could be intimidating if it really was "interrogator" as in to interrogate someone, looks to me like it is "integrator", as in to integrate two things together 8)
integrator in reply to blue_noteJun 23, 2010. 3:45 PM
You got it right blue_note. It's what I do for a living, integration of low voltage systems.
integrator in reply to Fred82664May 10, 2010. 3:10 PM
Why do you find my ID intimidating? Does anybody else find it intimidating? Should it be?
scorallo in reply to Fred82664May 2, 2010. 10:35 PM
Do you watch movies? Pay for cable or sat? Listen to music?
EXACTLY
so shut up - I’m so tired of people harping on 'entertainment' when they use it EVERY day.  People need these things - if you don't want to do it then why bother talking about it so much????
I can only conclude that you are either jealous (can’t imagine why), or just looking for an argument - neither of which is particularly commendable.
That said, I understand what you are saying, but it is the manner in which you chose to say it and the way in which you continued to talk about it that bothers me.  If you are not open to other people's hobbies and pastimes then why would we care about yours?
Also rolling on laughing f@&king a$$ off makes no sense
Fred82664 in reply to scoralloMay 3, 2010. 10:17 AM
First of all I do not dog on no one that dose not start on me first. so Your telling me to shut up shows you have a small span of intelligences.
  "Also rolling on laughing f@&king a$$ off makes no sense" tells that you do not have nothing to imagine with
"I can only conclude that you are either jealous (can’t imagine why), or just looking for an argument - neither of which is particularly commendable."  You think you know me . You do not know me so do not act like your someone that dose. That shows your fake  nor am I looking for Commendably. I pointed out one down side and it seem that every one has an affiances over it. If what ever I or any one else says bothers you. That is on you I thank you for the free rent I have in your head. My thank you is more then you will get from any one else that eats at you! oh and by the way I am vary open to other peoples hobbies and personally I care less if any one is in to my hobbies or not. I do for my self  every one else is little to nothing to my likes
blue_note in reply to Fred82664Jun 23, 2010. 2:40 PM
For the record, ROLFAO, makes no sense at all. The accepted vernacular is ROTF, rolling on the floor, and LMFAO, laughing my f*cking *ss off.
Saturn V in reply to Fred82664May 10, 2010. 2:15 PM
You tell 'im!
scorallo in reply to Fred82664May 3, 2010. 6:00 PM
Personal attacks and assumptions about my character do little more than to assert my initial remark and open yourself up for contradiction.  Your comment 'you think you know me,' is particularly interesting as it could easily be turned upon itself.  Implying that I think I know you means that you think you know me, and so on.  Interesting as this paradox may be, it is also the contradiction that exposes my next point - your continuation of this debate.  The tender meat of my statement was not that you are jealous (you are obviously not), but that you are perpetuating argument.  I have no qualms about your OPINION, it is yours after all.  However, you have also failed to acknowledge the section of my previous comment in which I agree with you.
Not because we share the same opinion, that much is obvious at least - but the part in which I admit that although my opinion (stated above) is a constant source of aggravation for me, I UNDERSTAND YOUR SIDE OF THE ARGUMENT AS WELL.  And I think you will find that if you skim the previous replies to your comments, you will notice that I am the only one who does.  Thus far you are the only person I have encountered with a valid argument on this particular topic.  The issue of what we invest vs. what we take away from something (in this case entertainment) is especially relevant today.  I was merely stating that it was the way in which you presented your argument that bothered me.
In retrospect, I think I should actually apologise for the rude way in which I expressed my frustration as it said just as much about me as I have interpreted it to say about you.  these assumptions however have no place on this site - and I do not wish to further blemish the page of this informative and well put together instructable.
Therefore:
I am sorry for my frustration and the way in which I expressed it - it was of poor taste on my part.  I also want to assure you that I make no assumptions about your character: your dedication and affirmation in your beliefs and values is actually quite admirable.
We all have bad days, I should not have taken mine out on you - however, I think we should all be a little more careful to avoid argumentation on forums.
Also, and somewhat unrelated - I actually enjoyed reading your last post.  Your argument was very well styled and organized, it was zippy and to the point.  I always appreciate good writing, even if it used against me :P
all the best
Fred82664 in reply to scoralloMay 3, 2010. 10:43 PM
PEACE Mr Scrallo ! one of my hobbies is to play around with sociology experiments. seeing how people tic is one thing another is to see how far another person will go is a insight of its self. The shots we both took at each other was cheap on both of us. I will say that you ended it with vary good style ! I therefor lower my foil and shake your hand. Sounds like you and I might of read some of the same books .
scorallo in reply to Fred82664May 4, 2010. 7:08 PM
cheers!
Pie Ninja in reply to Fred82664Apr 26, 2010. 10:42 PM
Grammar, please.
Fred82664 in reply to Pie NinjaApr 27, 2010. 11:33 AM
For the New people on line get with it and learn the language  of the INTERNET!!!!!!! OR just set back look around and say nothing let  us who been on line a long time ALONE !!!!!!!!!!!
lol = Laughing Out Loud
ROLFAO = Roiling On Laughing F@&King  A$$ Off
integrator in reply to Fred82664Apr 27, 2010. 2:31 PM
I don't think that was the area in which your grammar is lacking. I think it was the sentence structure that is bothering Pie Ninja. Or rather, the lack of sentence structure. Spelling and using the proper homonyms might be bothering him also.
BTW, I found my first 3 caches yesterday. Cost me about $2.50 in gas. Enjoyed an hour and a half outside, in the park and the woods, and at a veterans memorial. About the same as renting a movie.
purplemonkeydishwasher in reply to Fred82664Sep 4, 2008. 10:41 AM
The whole point of geocaching is BEING ENVIRONMENTALLY FRIENDLY! He didn't say you couldn't walk or bike. Chances are, if you live near a public park over 4 acres in size there is a wide selection of caches. And don't forget nano and micro caches. Tiny caches like them (some as small as a fingernail) are hidden in all sorts of urban locations.
Dr.Bill says: May 23, 2010. 2:49 AM
I've done something like this with ham radio. We call it FoxHunting.
We use a hidden low power transmitter hidden by 1 person and found by teams of amateurs radio operators with special antennas and receivers.
WH7WP
73's
Dinokabino1 says: Apr 26, 2010. 5:26 PM
I been doing geocaching sence May of 2001 ~~!! I can't get out and look my legs have gave out~~!!  My cach is at Mills Creek Sandusky, Ohio 44870
Dinokabino
W8DHP
Dillis says: Sep 6, 2008. 3:04 PM
Are you disallowed from keeping coins? (Why does it say "removed by community request"? I deleted that post myself.)
teapotking in reply to DillisApr 25, 2010. 8:37 AM
 You can find them on Ebay to buy and hide yourself if you want to make a new cache, So I would assume that you could Just keep it if you wanted to, allthough that's not really in the spirit of geocaching, is it?
dummy1977 says: Mar 11, 2010. 3:31 PM
Sadly, the DNR would go apeshit if they saw us trying to do any of this around what forest there is here in the midwest.  Why? Exactly.
james.mcglashan says: Sep 11, 2009. 5:10 PM
Spint says: Jun 14, 2008. 11:22 PM
Urban caching is my favorite, way more places to hide stuff. Lots of fun at 12 midnight, otherwise people are always wondering and asking why your searching in little holes in the ground and such.
natethegreat88 in reply to SpintAug 31, 2009. 8:24 AM
But at midnight they would probalby be even more suspicous if you were looking in little holes. They might think thats were "your friend" left "the stuff".
Spint in reply to natethegreat88Aug 31, 2009. 10:11 AM
Lol true, I guess you just don't know how suspicious they are because you can't see them.
natethegreat88 in reply to SpintAug 31, 2009. 12:58 PM
Yeah
1-40 of 65Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
